Spacer issue
Wrigers
Spacer issue
#1 PostAuthor: Wrigers » Fri Jan 25, 2019 3:43 pm
Can anyone assist with the correct thickness of the rear left hand spacer on the Z9.
It's the one that sits in front of the sprocket. The one I have is 15mm thick and causing a few issues.
8 Valve Mark
Re: Spacer issue
#2 PostAuthor: 8 Valve Mark » Fri Jan 25, 2019 11:39 pm
what's the issue paul? 15mm seems a bit short (width wise) from memory.. m
Re: Spacer issue
#3 PostAuthor: Philippe » Sat Jan 26, 2019 9:13 am
Hi Wrigers
15 mm seems to be the correct width...did you put the sleeve of the sprocket carrier the corect way in? Just check that out.
Wrigers
Re: Spacer issue
#4 PostAuthor: Wrigers » Sat Jan 26, 2019 2:36 pm
Best explained with a couple of photo's I think.
The rear end came with a concoction of spacers, I've already replaced the right one, now correct.
When the full wheel is offered up to the swinging arm, it won't go in by around 5mm. That's why I think the spacer is wrong and possibly from another model.
Duane (dd900) might have one and I can compare the two.
Wrigers
Re: Spacer issue
#5 PostAuthor: Wrigers » Sat Jan 26, 2019 3:04 pm
Think I've sorted it. Found this info on Z1 Part Aus....
Thinner than mine by around 5mm.
marmck
Re: Spacer issue
#6 PostAuthor: marmck » Sat Jan 26, 2019 3:07 pm
As Phillippe said take off your sprocket & turn the spacer around the one that has a collar on it ,my spacer only comes out of the sprocket 5mm yours appears to be about 10mm
Wrigers
Re: Spacer issue
#7 PostAuthor: Wrigers » Sat Jan 26, 2019 4:39 pm
Yes, right way round.
Re: Spacer issue
#8 PostAuthor: Philippe » Sun Jan 27, 2019 9:28 am
Hi Wrigers
the spacer of a z900 is 10 mm thick (n° 42037023), the spacer of a Z1000 is 15 mm thick,(n°42032071) I think you have a Z1000 spacer.
Sorry about my previous mail :blush
Took one out of my spares box, was a Z1000 spacer...
Wrigers
Re: Spacer issue
#9 PostAuthor: Wrigers » Sun Jan 27, 2019 11:37 am
Thanks for that Philippe, i think the previous owner threw in a mixture of z1000 bits.
DDZ900
w
#10 PostAuthor: DDZ900 » Sun Jan 27, 2019 3:01 pm
Wrigers ! if you are using that z900 hub i sold you i have the proper spacer for it !
Wrigers
Re: Spacer issue
#11 PostAuthor: Wrigers » Sun Jan 27, 2019 4:04 pm
Sent you a pm mate, ,,,,
Users browsing this forum: No registered users and 115 guests
