dual disk
dual disk
#1 PostAuthor: deka » Mon Feb 18, 2019 10:15 am
No sure if I have seen this or I may be just making it up!
can you use two 7.5 mm disks on the z900a4 from end with the dual disk conversion or do I need 4.5mm disks. yes I have callipers etc.
am sue I saw something that said the two 7.5 would not fit, I haven't put the from end back together yet so I have not tried but thought I would ask the question first
Re: dual disk
#2 PostAuthor: ADRIAN H » Mon Feb 18, 2019 10:31 am
I have dual 7mm discs on my Z1B, cant imagine Z900 is different !
Mathh
Re: dual disk
#3 PostAuthor: Mathh » Mon Feb 18, 2019 3:25 pm
I have two 7.5mm discs on my kz900 as well. Just added a second one with the same thickness.
Re: dual disk
#4 PostAuthor: deka » Mon Feb 18, 2019 8:10 pm
Thanks. Guys. I must have imagined it I could not think why it would make a difference but it’s always best to ask :happy
Re: dual disk
#5 PostAuthor: Philippe » Tue Feb 19, 2019 6:22 am
Hi Derek
you can mount two KZ900 A4 or A5 7mm thick discs on the Z900A4 hub. The thick discs only increase the unsprung weight of the front wheel. But they fit as long as they have 4 holes for the disc bolts !
needaz1100r
Re: dual disk
#6 PostAuthor: needaz1100r » Tue Feb 19, 2019 4:22 pm
By the time you have 2 x 7mm discs on the front you need another disc somewhere else to assist with stopping something that weighs as much as a half loaded artic. Have you ever dropped one of those 7mm discs on your big toe? :lol: :lol:
Mark.
Re: dual disk
#7 PostAuthor: ADRIAN H » Tue Feb 19, 2019 4:28 pm
needaz1100r wrote:By the time you have 2 x 7mm discs on the front you need another disc somewhere else to assist with stopping something that weighs as much as a half loaded artic. Have you ever dropped one of those 7mm discs on your big toe? :lol: :lol:
:smak :smak :smak
apologies could not resist. :sou
needaz1100r
Re: dual disk
#8 PostAuthor: needaz1100r » Wed Feb 20, 2019 7:30 pm
:smak :smak :smak
:oops: :lol:
Mark.
Users browsing this forum: Maunders and 68 guests
