Removing A4 Headlight Brackets
Andrew_s
#1 PostAuthor: Andrew_s » Thu Feb 28, 2019 7:52 am
To remove and replace the headlight brackets on my A4 what's the best/easiest method - drop the fork legs or remove the upper triple clamp etc?
Grateful for some advice.
Many thanks
Andrew
Current Bikes:
2023 R1250 GSA
Re: Removing A4 Headlight Brackets
#2 PostAuthor: warren3200gt » Thu Feb 28, 2019 8:03 am
Bike on center stand, jack with wooden block under the engine, lift the front end high enough to get the front wheel out, slide the legs down ehough to be clear of the headlight bracets, put the new ones in and reverse the procedure. Keep an eye on the brake pipes or unbolt the callipers.
Andrew_s
#3 PostAuthor: Andrew_s » Thu Feb 28, 2019 8:19 am
Brilliant, thanks Warren - that makes life a little easier, hopefully!
Andrew
Current Bikes:
2023 R1250 GSA
#4 PostAuthor: warren3200gt » Thu Feb 28, 2019 8:53 am
A bit half a dozen of one and six of the other really Andrew.
#5 PostAuthor: ADRIAN H » Fri Mar 01, 2019 9:33 pm
Fork legs lowered one at a time is a lot easier.
#6 PostAuthor: Garry.L » Sat Mar 02, 2019 2:00 pm
ADRIAN H wrote:Fork legs lowered one at a time is a lot easier.
What he said....
Much easier to do one at a time if you're not removing the front end.
