Clock mounting rubbers
Gonzo
#1 PostAuthor: Gonzo » Thu Feb 28, 2019 8:27 pm
I have just removed my clocks for a refurb and was greeted by this...
Missing bulbs (thought it was a bit dim on evening rides home). Extra foam of varying densities.
The amount of botched crap I have uncovered on something that looks ok on face-value is astounding!
My question is; which rubber mounts are correct for a Z1000A2 - Saisei and Z-power both have two types!?
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Re: Clock mounting rubbers
#2 PostAuthor: z1bman » Thu Feb 28, 2019 10:55 pm
Gonzo
#3 PostAuthor: Gonzo » Thu Feb 28, 2019 11:10 pm
Thanks, but just below there are these...
https://www.cybike.co.uk/Shop/Products/ ... unting-set
What's the difference between a meter mounting damper set and a clock bracket mounting set?
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
scotty m
#4 PostAuthor: scotty m » Fri Mar 01, 2019 4:41 am
one set mounts the complete bracket to the bike, the other set mounts the individual gauges to the bracket
the link Z1Bman listed mounts the gauges to the bracket
the one you posted mounts the complete bracket assy to the bike
Gonzo
#5 PostAuthor: Gonzo » Fri Mar 01, 2019 7:44 am
Great, many thanks to you both.
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
BigZCas
#6 PostAuthor: BigZCas » Fri Mar 01, 2019 6:56 pm
I have used the Cybike clock mount rubbers and they fit A1 :)
If you are not powder coating the bracket i would leave the foam as it is :??
Past 5 Years
1978 KZ1000a2, Luminous Green
1976 KZ1000a1, Red
1972 GT750J, Candy Lavender
Gonzo
#7 PostAuthor: Gonzo » Fri Mar 01, 2019 7:08 pm
BigZCas wrote:I have used the Cybike clock mount rubbers and they fit A1 :)
Cheers Cas, I plan to get a set from Dave although the foam is in a bad way and disintegrating rapidly with every touch. Was wondering if it might be worth cutting out some correct shapes from 'funky foam' and resticking?
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
BigZCas
#8 PostAuthor: BigZCas » Fri Mar 01, 2019 7:13 pm
I've tried cutting foam draft excluder in the past to save money, very tricky :oops:
Past 5 Years
1976 KZ1000a1, Red
Gonzo
#9 PostAuthor: Gonzo » Fri Mar 01, 2019 7:19 pm
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
KWACKERZ1
#10 PostAuthor: KWACKERZ1 » Sat Mar 02, 2019 6:52 pm
One of the guys on here did some from sticky back foam for me I photo copied them as templates so print this full size a4 and use them as a template.
Gonzo
#11 PostAuthor: Gonzo » Sat Mar 02, 2019 7:00 pm
Many thanks for that, Ive gone and bought some 5mm sticky back foam from Ebay, a 10mm hole punch and a scalpel today- total around £15. You'd think there would be a specific part what with all the Zed specialists out there these days!
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
8 Valve Mark
#12 PostAuthor: 8 Valve Mark » Sat Mar 02, 2019 8:59 pm
go for it gonzo, a bit of blue peter inventiveness should work fine!! make sure all adults have left the room before you start though. :lol: m
Gonzo
#13 PostAuthor: Gonzo » Sun Mar 03, 2019 10:48 am
Godamit, you're right... I can do this! :mrgreen:
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
guzziman56
#14 PostAuthor: guzziman56 » Sat Feb 13, 2021 3:13 pm
KWACKERZ1 wrote:One of the guys on here did some from sticky back foam for me I photo copied them as templates so print this full size a4 and use them as a template.
I'd appreciate some advice as I'm doing this job on my Z1000A1. Are the steel dowels supposed to bottom out when the clocks are tightened up?
Thanks Roger
1976 KZ1000A1, 1981 KZ1100 Shaft+Steib TR500 sidecar (ongoing), 1942 Motoguzzi 600U, 1948 Moto Guzzi GTV, 1952 Moto Guzzi Ercole (in bits), 1953 Nimbus, 1986 Moto Guzzi V65 Lario (in need of TLC), 1988 Moto Guzzi Mk V Le Mans
