Z1000 Rear Caliper
Z1000 Rear Caliper
Evening all, I am trying to get hold of a Z1000 rear Caliper, I am after an A1 type, not the custom type that uses a front style Caliper, if that makes sense. Thanks. Sean.
Re: Z1000 Rear Caliper
Hi Sean
to my knowledge all the Z1000 rear brake calpers were the same. Those of the Z1000A1, A2, A3,A4, Z1R are usable to you. The only thing that's different are the calper pistons. The pistons had an insert when Kawasaki started using sintered brake pads.
Maybe that widens your search.
- 8 Valve Mark
z1000 b (ltd) were different. (custom type walshy?) m
There are a few on ebay - but failing that - I believe I may have a spare rear calliper.
I bought it about 5 years ago and never used it.
I can pm you some pictures with more details if still required, and maybe you will be able to tell if it is what you are after.
Kevin
Kevin
010
PM sent. Thanks.
Thanks to Kevin (Kev1R) for the rear brake Caliper, very happy with it and thanks to Phillipe for sharing some of his very impressive wealth of knowledge. Sean.
