Welding
Re: Welding
#16 PostAuthor: zed1015 » Wed Mar 20, 2019 7:06 pm
Here's a couple of pics.
First one is with mounts straight on top of the arm and the second is with the wider stock mounts.
scott
Junior Section leader
Re: Welding
#17 PostAuthor: scott » Wed Mar 20, 2019 9:16 pm
Thanks for those Rob. Now I've fitted the grab it doesn't look too bad in the wider position. Still considering moving them a bit like yours though :roll:
gsxkat
Re: Welding
#18 PostAuthor: gsxkat » Fri Mar 22, 2019 12:34 pm
Scott,
Use IG Welding Services behind the parade of shops on Allaway Ave, Paulsgrove. Ivan was recommended to me by a mate and ended up doing a lot of welding jobs for me including shock mounts. Normally beer money for small jobs.
Martin
scott
Re: Welding
#19 PostAuthor: scott » Fri Mar 22, 2019 12:38 pm
Martin, thanks very much indeed. I’ll get in touch with them at some point.
