Gpz1100b1 seat lock
scott
Junior Section leader
Gpz1100b1 seat lock
#1 PostAuthor: scott » Thu Mar 28, 2019 12:29 pm
Guys, my Gpz1100b1 has a seat lock on the left hand side of the bike. Should there be one on the right hand side as well?? If not, what should be on the right hand side? I have seen a picture of a Gpz/J/R with a seat lock on the right hand side, so a bit more confused than normal. Any answers??
rickm
Re: Gpz1100b1 seat lock
#2 PostAuthor: rickm » Thu Mar 28, 2019 12:46 pm
From memory, the only seat lock where you put the key in is on the left. This allows removal of the seat, but also operates both helmet locks (one each side). I'll have to check when I get home this evening.
H2B GPZ900R
#3 PostAuthor: z1bman » Thu Mar 28, 2019 5:42 pm
its a helmet lock
scott
#4 PostAuthor: scott » Thu Mar 28, 2019 6:17 pm
Another part to search for :lol:
rickm
#5 PostAuthor: rickm » Fri Mar 29, 2019 8:58 am
My bad (memory !)
Yes, the right side helmet lock does need a key, and bolts on just behind the shock mount.
H2B GPZ900R
Big Fluff
#6 PostAuthor: Big Fluff » Sat Mar 30, 2019 5:11 pm
scott wrote:Another part to search for :lol:
Next to the Unicorns horn I believe you'll find one :lol:
Best of luck.
scott
#7 PostAuthor: scott » Sat Mar 30, 2019 5:37 pm
Well, I found the seat lock, which was apparently hens teeth. I’m sure I’ll find one eventually.
scott
#8 PostAuthor: scott » Wed Apr 17, 2019 2:31 pm
Found a helmet lock and bracket.....£15
Users browsing this forum: Bing [Bot] and 100 guests
