Z1 front wheel spindle
Adrian90s
#1 PostAuthor: Adrian90s » Sun Mar 31, 2019 11:08 am
Hi guys
How do you remove the front wheel spindle?
The disc is off
Lots of heat applied and grip both ends and start unscrewing, or have I missed something?
engz1b
Re: Z1 front wheel spindle
#2 PostAuthor: engz1b » Sun Mar 31, 2019 11:35 am
i, i just unscrew the axle whilst in forks,{ loosening off the clamp on bottom of fork first on one side } then drop wheel out, axle should then unscrew, and tap out axle from wheel ,should not have to apply heat
#3 PostAuthor: ADRIAN H » Sun Mar 31, 2019 6:20 pm
You have to move to move calipers out the way.
Undo speedo cable.
Undo clamps at bottom of forks.
Whole wheel drops out.
Then undo axle nuts, may need a good sized ratchet for leverage but should not need heat
Adrian90s
#4 PostAuthor: Adrian90s » Sun Mar 31, 2019 6:42 pm
Adrian
Removed wheel, big adjustable on each end and no movement, perhaps I need to put the wheel back between the wheel clamps with one side loose to get a better grip on it
Adrian90s
#5 PostAuthor: Adrian90s » Mon Apr 01, 2019 6:31 pm
As I have the forks off the bike, I cant clamp one side up and loosen the spindle. What about snipping the spokes and taking the hub into work and clamping other end in a vice then getting a big spanner on the other , not left hand thread by any chance?
The rim has the 20 odd yr old tyre still on and should be easy to clamp and remove at a garage.
Does this plan stack up?
Ady
RB
Mine's a triple!
#6 PostAuthor: RB » Tue Apr 02, 2019 1:03 am
We ARE talking Z1 here and not Z900 ?
Soft wrap and clamp the Zinc (SOLID) end of the axle in a vice, if you are going to use heat then use minimal on the speedo drive end, and it should jut come undone normally, if you struggle then get a REALLY good wide adjustable that grips it snugly, use a scaff pole and undo in the normal way.
Lifes too short . . .
Adrian90s
#7 PostAuthor: Adrian90s » Tue Apr 02, 2019 4:53 am
Yep, talking Z1, confirms method that I'm going to use at work today.
#8 PostAuthor: ADRIAN H » Tue Apr 02, 2019 7:51 am
Adrian90s wrote:What about snipping the spokes and taking the hub into work and clamping other end in a vice then getting a big spanner on the other Ady
Should work. Last week I managed to undo a stubborn axle with two spanners, one taped to end then gently hit with a 2lb hammer. Helps if you have a spare pair of hands.
Adrian90s
#9 PostAuthor: Adrian90s » Tue Apr 02, 2019 5:52 pm
My method worked, snip the spokes out, take the hub to work and put the fixed end in a vice. Big adjustable on the speedo drive end. It gave eventually tho I did soak it over a few days with penetrating oil. Few scuffs on the flat bits what should I do? File the burs? Is it invisible with the clamps on? Chrome/zinc plate?
Ady
#10 PostAuthor: ADRIAN H » Tue Apr 02, 2019 7:40 pm
Any score marks on the flat will probably not visible, but will be a weak spot and could lead to corrosion.
It may be manageable, you could smear the damaged area with grease, (keep your fingers crossed), or get the axle re-plated.
Picture might help ?
Adrian90s
#11 PostAuthor: Adrian90s » Wed Apr 03, 2019 6:45 pm
The damage is more like a bur that's all, will clean up and leave I think. Not even worth a picture.
