Z650 refresh...
MDM
Re: Z650 refresh...
#196 PostAuthor: MDM » Tue Apr 02, 2019 1:11 pm
In the meantime, I got a velocity stack from out East. I'm not sure whether it'll stay, as I may go with a proper filter...
Z650/1100 turbo, GPz750 rolling resto, Z650 restomod
MDM
Re: Z650 refresh...
#197 PostAuthor: MDM » Tue Apr 02, 2019 1:12 pm
And the fuel tap that I found lurking in a cupboard, I just need to sort out a gasket for it.
MDM
Re: Z650 refresh...
#198 PostAuthor: MDM » Tue Apr 02, 2019 1:13 pm
A trip back to the old house later, and I had a box of bits...
In which was this little beauty...
And these as well. Yes, two of them...
Re: Z650 refresh...
#199 PostAuthor: chrisNI » Tue Apr 02, 2019 4:34 pm
At least you hadn’t bought another one.... I’ve been looking for a couple of engine spacers for months I know they must be there somewhere :shock:
MDM
Re: Z650 refresh...
#200 PostAuthor: MDM » Thu Apr 04, 2019 8:24 am
Hmm, after some online searching I can't find a gasket to suit this...
Re: Z650 refresh...
#201 PostAuthor: warren3200gt » Thu Apr 04, 2019 9:23 am
Pretty sure M&P do one.
PUM 488 June 2023
MDM
Re: Z650 refresh...
#202 PostAuthor: MDM » Thu Apr 04, 2019 10:01 am
M&P do lots of tap gaskets Warren! The problem is that I don't know what model fits this particular tap. I'm 99% sure that it's not a Z650 one... :wink:
Re: Z650 refresh...
#203 PostAuthor: warren3200gt » Thu Apr 04, 2019 10:04 am
looks to be 44mm holes centres? if so it'll be a later 650 tap from c2 onwards I think. B model ones didn't have the bolt hole isolator bars.
PUM 488 June 2023
MDM
Re: Z650 refresh...
#204 PostAuthor: MDM » Fri Apr 05, 2019 8:53 am
Yep, 44mm hole centres ;-)
I've really struggled to find one with the 'bars' , so have settled for a simple oval one from Z-Power, hopefully it'll do the trick...
Re: Z650 refresh...
#205 PostAuthor: Pigford » Fri Apr 05, 2019 9:05 am
Looks like older Gixxer tap size?
engz1b
Re: Z650 refresh...
#206 PostAuthor: engz1b » Fri Apr 05, 2019 9:38 am
looks like yamaha fazer 600 fuel tap gasket would fit
MDM
Re: Z650 refresh...
#207 PostAuthor: MDM » Wed Apr 29, 2020 10:29 am
I settled for a tap gasket from a GSX-R, without the 'bars' that cross it, although I also have a rubber Pingel gasket that could do the job if I trim it to open up the hole...
Yes,it has been a long time since I updated this thread. But that's nothing new is it?...
I managed to get the bits I needed to fit the starter clutch etc - Thanks Rob! - and the aftermarket starter clutch refurb stuff and a new needle roller bearing. But looking at the ring gear and idler gear, they were really nasty and smeggy, and the idler gear had what looked like bits of old magnet between the teeth, presumably from a knackered alternator...
Big Fluff
Re: Z650 refresh...
#208 PostAuthor: Big Fluff » Thu Apr 30, 2020 7:32 am
Bloody hell Davey lad, back on it are we :lol: :lol:
If you're over this way after the pandemic do let us know and we'll meet up with you and Billy.
Keep on with the project mate, I've bought another 3 since we last spoke!
Will
MDM
Re: Z650 refresh...
#209 PostAuthor: MDM » Thu Apr 30, 2020 3:30 pm
Cheers Will - yeah, back on it! Despite the lockdown I'm still working, but from home, so I'm managing to grab some more time in the garage, finally... work was drawn to an early finish last night though, when I couldn't find the bolt to hold the rotor onto the crank.... arse!
MDM
Re: Z650 refresh...
#210 PostAuthor: MDM » Mon May 04, 2020 12:02 pm
MDM wrote:I'm now wondering if I've got my lock-ups mixed up, as I'm sure I have another one somewhere that is supposedly for a GSX-R, maybe I got them confused? The problem is, I can't find it as it is also in a 'safe place'......
So, I found the six bolt lock-up that was tucked away in a box that hadn't been open in years. And was I happy? Er, no. It is, as expected, for a GSX-R... so I'm currently in the situation where I have a lock-up unit for a five stud clutch, while the bike has a six bolt clutch, and my spare is also six bolt. I could as Rob suggested earlier, get hold of an earlier clutch and it's stronger steel basket, or find a lock-up unit to suit the six bolt clutch that I've got loads of spares for...
