Z1000R Paintwork
scott
Junior Section leader
Z1000R Paintwork
#1 PostAuthor: scott » Wed May 01, 2019 10:01 am
Would anyone please be able to supply the codes required for a Z1000R 82 model paintwork. What code is it for the green? What code is for the blue and white stripes?
Re: Z1000R Paintwork
#2 PostAuthor: chrisNI » Wed May 01, 2019 4:19 pm
You can buy decals for the stripes. You could get the paint code for a green Zx7R I don’t think anyone would really argue - if they did you could tell them to f*** ** :D
8 Valve Mark
#3 PostAuthor: 8 Valve Mark » Wed May 01, 2019 4:25 pm
+1 to what chris says. although its more polite to ASK them to F*** OFF.
#4 PostAuthor: chrisNI » Wed May 01, 2019 4:36 pm
Sorry - I know you’re all very particular about etiquette up there... :D
scott
#5 PostAuthor: scott » Wed May 01, 2019 5:47 pm
Thanks guys. That’s the green sorted then. Where’s the best place to get the tank and tailpiece decals from?
#6 PostAuthor: Al » Wed May 01, 2019 6:00 pm
Have a word with these guys. Found them to give very good service and they will modify or adjust sizes, colours, lengths, etc. They also save details of whats been ordered by name so you can go back and get some more as i have done previously.
Also very good on price and when i went back three years after the fact they asked me 'how much they were last time'. 'That will be the same price again then'.
http://www.bike-stickers.com/homepage.htm
scott
#7 PostAuthor: scott » Wed May 01, 2019 6:25 pm
Thanks Al, I’ll get in touch with them.
If I use ZX7R green colour paint for the tank etc, will it require a coat of white underneath just like it had on my ZX7R. If the white base coat is not used then the colour won’t be right when finishing the green.
#8 PostAuthor: Al » Wed May 01, 2019 8:33 pm
scott wrote:Thanks Al, I’ll get in touch with them.
I was told years ago that ZX7R was the closest match you will get. Dont know about the white base but can ask the pug monkeys at work when i get back next week. I will get a mountain of abuse and an explanation that Alan Turing could not decipher but if it helps i can do that. :D Paint pansy no 1's standard response to any question is; F&^K OFF!!!!
scott
#9 PostAuthor: scott » Wed May 01, 2019 8:36 pm
Thanks Al. :D
scott
#10 PostAuthor: scott » Wed May 01, 2019 8:44 pm
.......and on the subject of tanks, I have two petrol tanks. One is destroyed by having a dodgy racing fuel cap fitted. It has a round threaded hole for the fuel tap, rather like the z1000a1. The other tank looks identical but has no round threaded hole. Instead there are two threaded holes either side of a larger hole, looks like the holes on a z1000a2. This tank is ok, maybe. But what tanks are they, Gpz, R1,R2, J ???
rickm
#11 PostAuthor: rickm » Thu May 02, 2019 7:40 am
Sounds like the second tank may be from a gpz1100b model, if the holes are on the right?
It should fit the frame ok, but you will have to plug some of the threaded holes.
H2B GPZ900R
scott
#12 PostAuthor: scott » Thu May 02, 2019 5:43 pm
Rick, both tanks have the fuel taps on the left. Looks like fuel sensor on the right. Both tanks look identical in every way except fuel tap fitment.
8 Valve Mark
#13 PostAuthor: 8 Valve Mark » Thu May 02, 2019 7:23 pm
hi scott, it sounds like the round threaded a1 type has possibly been converted for a pingel hi-flo tap.? m
scott
#14 PostAuthor: scott » Thu May 02, 2019 7:36 pm
I’ll put some pictures up of the good tank...I’ll just pluck up the courage for the photo bucket saga. :lol:
Gus
#15 PostAuthor: Gus » Fri May 03, 2019 8:16 am
Put the photo's on your PC/Laptop and upload them from there I find is easier.
Gus
"Set the GRINDER on it"
