Front break upgrade
Front break upgrade
Hi all
Could anybody tell me how I go about adding a second disc
Disc , calliper etc to my 1974 Z1b , as you know
they are double disc on later models so would
the existing wheel and forks work or need to replace them. Cheers
neilbarrett
- ZedHead
Re: Front break upgrade
you need second disc opposite caliper ,twin break line splitter ,second break hose ,twin disc master cylinder,fixing bolts etc,brake hose guide as well
Original twin brake set up also uses thinner disc's to reduce unsprung weight so you'd need to source 2 new discs if going down the factory route. ....
Never knew a z1b DD conversion used thinner discs, thought it was only z900/z1000 that used the thinner discs.
neilbarrett
- ZedHead
Garry.L wrote:Original twin brake set up also uses thinner disc's to reduce unsprung weight so you'd need to source 2 new discs if going down the factory route. ....
or have ya discs skimmed?
The simplest way would be to shove a Z650C front end in. You can reuse your spoke wheel
Z-Power will have all you need,
http://www.z-power.co.uk/z900-z1-z1a-z1 ... right-z1ab
http://www.z-power.co.uk/z900-z1-z1a-z1 ... isc-6-hole
http://www.z-power.co.uk/z900-z1-z1a-z1 ... ouble-disk
http://www.z-power.co.uk/brake-hose-bottom
http://www.z-power.co.uk/brake-pipe-metal--right
http://www.z-power.co.uk/bracket-brake-hose-right-003
http://www.z-power.co.uk/z900a4-kz900b1 ... -box-4-way
Zeds-R-Us
A1John wrote:Never knew a z1b DD conversion used thinner discs, thought it was only z900/z1000 that used the thinner discs.
Correct, the Z900-A4's came as standard in the UK with twin discs, which were thinner than the earlier Z1/A's/B's.
Upgrading the earlier Zeds to twin discs involved fitting a second thicker disc as the later thinner items had not been made at that point.
Also, the Z900 discs had four mounting bolts whereas I understand some of the earlier Zed discs had six mounting bolts.
BTW, GPz900R calipers fit straight on Z1000A2 for what it's worth, and work a helluva lot better than the standard single piston calipers.
- 8 Valve Mark
as already stated, the z1-z1b only came with a single 6 bolt disc, so the way ahead is to find a 2nd disc n the associated plumbing.the m/cylinder, 2nd caliper, pipes etc are readily available (or a PAIR of discs if poss?) look out for a drilled pair for best results. good luck. m
needaz1100r
- ZedHead
8 Valve Mark wrote:as already stated, the z1-z1b only came with a single 6 bolt disc, so the way ahead is to find a 2nd disc n the associated plumbing.the m/cylinder, 2nd caliper, pipes etc are readily available (or a PAIR of discs if poss?) look out for a drilled pair for best results. good luck. m
Mark.
Mark.
needaz1100r
- ZedHead
CAT3 wrote:A1John wrote:Never knew a z1b DD conversion used thinner discs, thought it was only z900/z1000 that used the thinner discs.
Z1, Z1A and Z1B discs and brake calipers are different animals to the later single (thick) or twin (thin) discs.
Z1 series discs are 6 bolt mount, Z900A4 onwards are 4 bolt.
Caliper bolt spacings are different.
I have a pair of Z1 discs if you (cabmonkey) wants to PM me.
Mark.
Mark.
needaz1100r
- ZedHead
000zeds wrote:Z-Power will have all you need,
or...
http://www.z-power.co.uk/double-disc-kit-z1ab
Mark.
Mark.
Big Fluff wrote:BTW, GPz900R calipers fit straight on Z1000A2 for what it's worth, and work a helluva lot better than the standard single piston calipers.
Would GPz900R callipers fit on a 1000J too ?
H2B GPZ900R
