Hi, I am after a single spring side stand for my Gpz1100b1. I have got the other type, but they dont fit.
Cheers Rob
Gpz1100b1 side stand
Re: Gpz1100b1 side stand
I've been after the original two spring UK type of stand for a while now to replace the US single spring type that's currently fitted to my J.
Interested to hear that you say the "other type" doesn't fit ?
I presume you mean the two spring type that was fitted as standard to UK bikes ?
H2B GPZ900R
- paul doran
I have an original two spring side stand found it last week while doing a tidy up
Al wrote:Single spring jobbie on ebay Germany.
https://www.ebay.co.uk/itm/Kawasaki-GPz ... Swp-5bnpxZ
That's the same as the one I've got.
Might be interested in a swop if the two spring version fits my bike?
H2B GPZ900R
The 'three' spring version bracket looks like this except the bit on the bottom where its hit the track
I didnt think they were interchangeable because the bracket is so much different and the three spring affair has so may closely working parts to it!!
That’s same as z1r D2-D3
THE ORIGINAL TARMAC TERRORIST
Z1OC # 886 till 2030
And there’s 2 for German and other markets to compensate for 19” wheel
German standard z1r
Twin spring set up u I’ll get the drift 18” and 19” wheel
Hi all, double spring with the bracket definitely doesnt fit. The postage on the German one is a bit steep though. I will keep my eye out for others.
Cheers Rob
Cheers Rob
Users browsing this forum: tim.25 and 56 guests
