Z900 forks
Dero
Z900 forks
#1 PostAuthor: Dero » Mon May 13, 2019 11:02 am
Hi, does anyone know of a pair of forks for sale to fit a 1976 Z900?
I want to refurb a set then just swop mine over.and keep mine as spares.
Dero
neilbarrett
Re: Z900 forks
#2 PostAuthor: neilbarrett » Mon May 13, 2019 11:04 am
think z1000 a seris may be the same ?https://www.ebay.co.uk/itm/Kawasaki-kz1000-z1000-kz900-z900-forks/233225017097?hash=item364d4b5709:g:Ng4AAOSwrw1csxc3
Gus
Re: Z900 forks
#3 PostAuthor: Gus » Mon May 13, 2019 11:09 am
According to Partzilla
This product fits the following:
Kawasaki Motorcycle 1976 KZ900-A4
Related Fitment
This Kawasaki 44001-175 FORK-FRONT Not Available fits the following models and components:
Kawasaki Motorcycle 1976 KZ900-A4 Front Fork
Kawasaki Motorcycle 1977 KZ900-A5 Front Fork
Kawasaki Motorcycle 1976 LTD - KZ900-B1 Front Fork
Kawasaki Motorcycle 1978 KZ1000 - KZ1000-A2A FRONT FORK (KZ1000-A1)
Kawasaki Motorcycle 1978 KZ1000 - KZ1000-A2 FRONT FORK (KZ1000-A1)
Kawasaki Motorcycle 1979 KZ1000 - KZ1000-A3A FRONT FORK (KZ1000-A1)
Kawasaki Motorcycle 1980 KZ1000 - KZ1000-A4 FRONT FORK (KZ1000-A1)
Kawasaki Motorcycle 1979 KZ1000 - KZ1000-A3 FRONT FORK (KZ1000-A1)
Kawasaki Motorcycle 1977 KZ1000 - KZ1000-A1 FRONT FORK (KZ1000-A1)
Gus
"Set the GRINDER on it"
Dero
Re: Z900 forks
#4 PostAuthor: Dero » Mon May 13, 2019 12:53 pm
Thanks Gus
needaz1100r
Re: Z900 forks
#5 PostAuthor: needaz1100r » Mon May 13, 2019 1:13 pm
Gus wrote:According to Partzilla
Related Fitment
Gus
Be careful, this is misleading as it is the way the parts fiches are labelled. only theZ900A4 or A5 and the Z1000A1 from 1977 has the same forks, the A2, A3 A4 from 1978 and 1979 are not the same as they have calipers behind the leg.
That is what the list above says, if you read it carefully, but it would be easy to think the A2 etc also do, but it's the way the fiches are accessed.
Mark.
Re: Z900 forks
#6 PostAuthor: warren3200gt » Mon May 13, 2019 1:30 pm
77 650b are the same also. Front caliper.
Re: Z900 forks
#7 PostAuthor: chrisNI » Mon May 13, 2019 4:01 pm
I’ve got one for some reason - it’s a LH stamped K220L inside the leg, it’s missing the axle cup. I can put up pics if it might be any use. It’s probably off a Z1000A1. Been sitting for years but would refurb.
000zeds
Re: Z900 forks
#8 PostAuthor: 000zeds » Mon May 13, 2019 5:32 pm
warren3200gt wrote:77 650b are the same also. Front caliper.
Z650 Fork legs are shorter :!:
Zeds-R-Us
Re: Z900 forks
#9 PostAuthor: warren3200gt » Tue May 14, 2019 9:39 am
Good spot, by about an inch and half.
Dero
Re: Z900 forks
#10 PostAuthor: Dero » Tue May 14, 2019 3:00 pm
Thanks for the help gents
malc87
Re: Z900 forks
#11 PostAuthor: malc87 » Thu May 16, 2019 7:25 am
Think i might have some if your still looking, would have to dig them out of the pile of H2 forks there with :oops:
Jerry
President
President
Re: Z900 forks
#12 PostAuthor: Jerry » Tue Jun 11, 2019 5:18 pm
I've got a pair in the garage pm me if you don't get sorted. They have the oil drain screw on the opposite side to the caliper mounts.
