Z1-R Swingarm spindle size and possibly wanted.
Anybody know the swingarm spindle size for a Z1-R length and diameter, maybe after one.
Re: Z1-R Swingarm spindle size and possibly wanted.
Z1r spindle size 30.7cm total length , 29.5cm useable spindle length , 20mm diameter
Swingarm spindle is 16mm ( although they actually measure 15.8mm )
Think you may mean the wheel spindle though ?
yes the swingarm spindle, the frame will be here next week so got nothing to measure at the mo, bearings seem to be 16mm and the Davida arm ive got is out of a H**** so is slightly to wide so a bit of modification is required, just measuring and initial searches for the right size bearings
sorry misread thought u wanted wheel spindle
but your welcome anyway
Stock frame is average 234mm to 235mm inside width unsprung for swingarm and 304mm outside width at the s/a spindle so you need that plus 20mm or so for threads and nut.
zed1015 wrote:Stock frame is average 234mm to 235mm inside width unsprung for swingarm and 304mm outside width at the s/a spindle so you need that plus 20mm or so for threads and nut.
Ideal thanks
