Hi,
In urgent need of one or more exhaust cam caps. Could get away with just the one numbered one or three. My number one has been installed the wrong way around at sometime and the camshaft is floating. Why I don't know! Now allowing the cam to move over and catch.
Please PM or call on 07511801197
Wanted Cam Caps-Z1or Z900
wilsonsjw11
Re: Wanted Cam Caps-Z1or Z900
I assume you know these items were line bored thus matched to the head.
Regards
Steve
Regards
Steve
Hi Steve,
Yes, I appreciate they were, but I've little option other than to adapt one to check the cam end float which is catching. I may try and repair the damaged one.
Hi PJONO
There are different cam caps in the Z1-Z900 series...they change nearly every year of production. It's very important that you have the correct cam caps so that they align . As stated before by Steve: they were line bored with the head!
You may be lucky finding cam caps that fit your cylinder head but take care.
Have you tried to use new camshaft shells? This might solve your problem.
I hope you find a solution!
yes I might try new shells. Cant hurt
