Regulator or rectifier?
john-meyer
Location: Tall Trees,Chequers Lane,Saham Toney,Thetford Norfolk IP25 7HQ
#1 PostAuthor: john-meyer » Tue Jun 11, 2019 7:25 pm
Bike-Z1000A1
Problem- Battery shows 9 volts with engine off. Jumps to 12 volts when on tickover but goes DOWN when revs are increased.Neutral light /rear light flicker on tick over, Indicators flash too quickly and battery does not charge. I duspect rectifier but maybe regulator or something else? Any ideas would be appreciated,
Regards, John
two heads are better than one ...even if they are only petrolheads[color=#BF0000][/color]
moizeau
Re: Regulator or rectifier?
#2 PostAuthor: moizeau » Tue Jun 11, 2019 9:02 pm
Have a read through this to get an understanding of how it works a basic tests.
https://www.denniskirk.com/learn/how-to ... motorcycle
(I have had no dealings with the site)
#3 PostAuthor: Ultim8pc » Wed Jun 12, 2019 9:02 am
You need to check thee battery and all components of the charge circuit.
Wrigers
#4 PostAuthor: Wrigers » Wed Jun 12, 2019 12:27 pm
Take a look at this link, it helped me...
http://motorcyclemd.com/how-to-fully-tr ... ng-system/
scott
Junior Section leader
#5 PostAuthor: scott » Wed Jun 12, 2019 3:02 pm
Sounds like you might have a battery cell dropping out intermittently. I had this happen on a gel battery once.
8 Valve Mark
#6 PostAuthor: 8 Valve Mark » Wed Jun 12, 2019 6:59 pm
+1 to Scott's theory, but also worth checking the earth side from the battery too.. good luck. m
moizeau
#7 PostAuthor: moizeau » Wed Jun 12, 2019 7:10 pm
Can you ride it, if you've got a cell down it will sap the juice from the alt and it will bog down or cut out in my experience, what's the battery like off the bike?
scott
#8 PostAuthor: scott » Wed Jun 12, 2019 8:09 pm
Mine did both, bogged down or cut out.
john-meyer
#9 PostAuthor: john-meyer » Thu Jun 13, 2019 7:45 pm
Thanks all for your help. Today replaced old regulator and rectifier with Z power combined unit.-No change, so did more poking around and removed the flasher and hazard relays-.Now the bike charges and everything ok,except flashers obviously. Borrowed the same two relays from my other Z and everything works ok.I am not bad with electrics but cannot understand how a duff flasher or hazard relay can affect the charge circuit=no wonder people hate electrical problems!!!=just got to find a replacement hazard relay which no one seems to list.Flasher one is no problem.Regards John
john-meyer
#10 PostAuthor: john-meyer » Mon Jun 17, 2019 10:08 pm
Hi all , that was not the end of the story after all! Even with the flasher relay replaced,today still only had 9.6 v at battery.Even with engine running this would only increase marginally but flashers and headlamp were ok.So I fitted a new battery as suggested in your replies and allseems good now. 12.4 volts with engine off.Once the engine starts,12.6 volts,rising up to 13volts after o couple of minutes running and staying there even with main beam on,with engine on fast idle. So with the reg /rectifier replaced and a new battery,any further problems will point to alternator or bad wiring maybe at the four plugs on the sub loom-taking it out for a test ride tomorrow so we shall see!
scott
#11 PostAuthor: scott » Tue Jun 18, 2019 8:00 am
Electrics are so much fun :roll:
Users browsing this forum: No registered users and 99 guests
