1977 Z1000A1 Tank
JohnC
1977 Z1000A1 Tank
#1 PostAuthor: JohnC » Wed May 22, 2019 9:33 am
Hi does anyone have a decent (hens teeth!!) Z1000A1 tank. I had mine painted by Flying Tiger, a cracking job, but unfortunately now a good many years later the tank is now porus and the paint is bubbling in a couple of spots. I had the tank sealed by a 'supposedly' professional company but they made a complete botch of it and ended up cutting up the tank to seal it. So I doubt if its worth having another go. Z Power can get them new but they are a bit hit and miss according to Phil and I'd rather not go down that route if it might ruin another paint job.
JohnC
Re: 1977 Z1000A1 Tank
#2 PostAuthor: JohnC » Thu Jun 13, 2019 1:58 pm
Bump just in case!!
Swirl
#3 PostAuthor: Swirl » Thu Jun 13, 2019 6:32 pm
I have often thought about all these rusted tanks, I wonder why someone has made a bag to go inside and be blown to shape or injection moulded type of affair and still be able to use the old tank as a outer case, I know it doesn't help your cause but a good conversation
JohnC
#4 PostAuthor: JohnC » Mon Jun 17, 2019 12:16 pm
I guess that would work, wish I had the brains to invent and market this :D
Dero
#5 PostAuthor: Dero » Sat Jun 29, 2019 7:22 pm
Hi
Have you found a tank yet?
I bought one for my 1976 Z900 so that I could use my bike while mine was off being painted.
Ended up the painter wasn’t busy and completed mine in a week so I never used the one I bought.
If you still need it I’ll sell you this one.
Regards Derrick
#6 PostAuthor: paul doran » Sat Jun 29, 2019 8:06 pm
I have an a1 tank
it has a vacume tap
King of Kings
#7 PostAuthor: King of Kings » Sat Jun 29, 2019 9:07 pm
Wouldn’t that be an A2 tank?
8 Valve Mark
#8 PostAuthor: 8 Valve Mark » Sat Jun 29, 2019 10:07 pm
an a1 tank is a very different tank and a one year only specimen, it's physically similar looking to the z9 tank with a screw tap fitting (but the underside profile is totally different) and has on/off/res positions: the a2 tank has a 2 bolt fitting tap with vacuum facility n prime option..apart from that they're identical! :lol: I'm off to wash my anorak. m
#9 PostAuthor: paul doran » Sat Jun 29, 2019 10:34 pm
mines ultra common A2
8 Valve Mark
#10 PostAuthor: 8 Valve Mark » Sat Jun 29, 2019 10:45 pm
not THAT common either paul, always valuable to someone mate!! regards m.
