Z1R Seat Lock Plate
wheelysteve
Z1R Seat Lock Plate
#1 PostAuthor: wheelysteve » Thu Jul 25, 2019 1:46 pm
Anybody know how to remove the chrome swivel plate on the seat lock fora Z1R?
I have pushed and clouted it but I don't want the damage the tailpiece. I can't see what holds it in place.
Cheers Steve
1975 Z1B Candy Red/Blue
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
Re: Z1R Seat Lock Plate
#2 PostAuthor: Philippe » Thu Jul 25, 2019 3:48 pm
Hi Steve
when you remove it, it's almost sure that you're going to damage it...
The lock cover has a split shaft in which the end of a spring is located. The two halves of the shaft are reasonably soft and must be bend in order to release the spring. Once the spring is free, the lock cover can be removed.
Just take care and if you break it, let's hope you can buy another.
Good luck
wheelysteve
#3 PostAuthor: wheelysteve » Thu Jul 25, 2019 5:20 pm
Thanks Philippe. I've got the spring off but the swinging bit does not want to come out of the tail piece.
I'm reluctant to push it too hard on a 40 yr old bit of plastic
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
#4 PostAuthor: Al » Thu Jul 25, 2019 6:54 pm
Legend Motorcycles do a new replacement cover / spring if it all goes west. Not sure if its genuine but wants to be for about £45.
KeithZ1R
#5 PostAuthor: KeithZ1R » Fri Jul 26, 2019 6:50 am
Either the previous owner has glued it in or it is full of crap try soaoking with some realeasing fluid, or similar. I suppose the obvious question is " does it swing through the 90' that is required to open the seat cover ? If it it does then the spring holding tangs are probably too wide apart...either way if it alll goes tits up
http://www.z-power.co.uk/tail-piece-flap-z1-r
Keith
:bop :gom
mistaken.
Phil Churchett winner 2013
KeithZ1R
#6 PostAuthor: KeithZ1R » Fri Jul 26, 2019 6:50 am
Keith
:bop :gom
mistaken.
hartyb
#7 PostAuthor: hartyb » Fri Jul 26, 2019 12:14 pm
there is a bit in Tony Sculpher book page 140 about fitting maybe you can use this information to help get it off
Z1300 A1,
ZZR1100 Purple and orange
KE175b, KE175F
wheelysteve
#8 PostAuthor: wheelysteve » Sat Jul 27, 2019 10:45 am
I think someone has had a previous attempt and distorted it. I've given it to Sean Dewis who is going to paint it. He said he will drill it out.
1975 Dogs Z1B
1976 Z900 A4
1977 Z650B1
1978 Z650B2
1978 KZ1000D Z1R
Yam Tracer 900GT
PUM 710
#9 PostAuthor: Bill P » Sat Jul 27, 2019 10:52 am
Good painter that lad :)
