Neutral switch
DavidZ1R
Neutral switch
#1 PostAuthor: DavidZ1R » Fri Aug 02, 2019 8:32 pm
Got a problem with my 650 project, the neutral switch does not connect with the drum, I have a new switch and that's the same, looks about 1mm short, what could be the problem, selector cap worn? Any tips?
Re: Neutral switch
#2 PostAuthor: z1bman » Sat Aug 03, 2019 12:58 pm
yes could be the end plate worn or damaged not a big job to get the sprocket cover off & have a look
DavidZ1R
Re: Neutral switch
#3 PostAuthor: DavidZ1R » Sat Aug 03, 2019 1:20 pm
Sorted thanks Paul, I did just what you suggested, then remembered I put a newer inside sprocket plate on because the old one had suffered a chain snap I think, had been welded up by the side of the neutral switch, anyway when I checked the plate it had been pushed in about 1.5mm, so I put it straight, all good now light works as it should , cheers. :hoo
Users browsing this forum: bigdjag and 37 guests
