Neutral switch
Neutral switch
Got a problem with my 650 project, the neutral switch does not connect with the drum, I have a new switch and that's the same, looks about 1mm short, what could be the problem, selector cap worn? Any tips?
Re: Neutral switch
yes could be the end plate worn or damaged not a big job to get the sprocket cover off & have a look
Re: Neutral switch
Sorted thanks Paul, I did just what you suggested, then remembered I put a newer inside sprocket plate on because the old one had suffered a chain snap I think, had been welded up by the side of the neutral switch, anyway when I checked the plate it had been pushed in about 1.5mm, so I put it straight, all good now light works as it should , cheers.
