When idling at app 1k there is a distinctive noise, rattle that completely goes and the idle settles when I pull in the clutch.
Any advice to remedy please.
Z900 A4 Cutch
Z900 A4 Cutch
Bike now finished what a joy!
Re: Z900 A4 Cutch
It's fairly common for the clutch housing springs to work lose. Kits are available although the rivets need welding. Buzzard can fit them for you.
Re: Z900 A4 Cutch
Is there any information on this that I can you for reference?
Re: Z900 A4 Cutch
Wayne1960 wrote:Is there any information on this that I can you for reference?
There is an article in last yearbook or PM Buzzard on here.
Re: Z900 A4 Cutch
Worth checking carbs are balanced correctly, carbs out can cause a noisy clutch on idle.
