Washer Plate
Wayne1960
Washer Plate
#1 PostAuthor: Wayne1960 » Fri Aug 30, 2019 10:15 am
Is there anyone making these washers? don't think they are available anymore
Its the double tab washer that goes under the throttle slide adjuster on Mikuni VM 26s
Part number 16054-008
Bike now finished what a joy!
Re: Washer Plate
#2 PostAuthor: ZedHead » Fri Aug 30, 2019 11:00 am
No longer available under that part number. I could get some laser cut in stainless from a sample if there is demand?
Gus
Re: Washer Plate
#3 PostAuthor: Gus » Fri Aug 30, 2019 11:24 am
"Set the GRINDER on it"
MikeP
Re: Washer Plate
#4 PostAuthor: MikeP » Fri Aug 30, 2019 12:33 pm
:shock: :shock: :shock: how much!!!!!
Wayne1960
Re: Washer Plate
#5 PostAuthor: Wayne1960 » Fri Aug 30, 2019 1:29 pm
Managed to get some from CMS
johny brando
Re: Washer Plate
#6 PostAuthor: johny brando » Sat Aug 31, 2019 12:27 am
Wayne1960 wrote:Is there anyone making these washers? don't think they are available anymore
Hi Wayne, nip down your local hard wear shop & buy some thin sheet- tin or brass & make 8 up yourself .........it won't take long ! & it will cost less than buying them too. Cheers.
Wayne1960
Re: Washer Plate
#7 PostAuthor: Wayne1960 » Sun Sep 01, 2019 7:52 am
Hi thanks for the info. Once i took them off and flattened them out they looked ok. They looked crap installed but look fine now.
Users browsing this forum: No registered users and 145 guests
