Z1000 Rear engine brackets
Does anyone know if Z1000 rear engine plates will fit A4? They look similar but part numbers differ.
Re: Z1000 Rear engine brackets
they are both the same if your using the csml site the right side engine plate has a incorrect part number
I thought they were different as the z900 has a drum rear brake.
But they are the same.
link to a Z900 one on ebay
https://www.ebay.co.uk/itm/Reconditione ... xyBXNSVAt3
z1bman wrote:they are both the same if your using the csml site the right side engine plate has a incorrect part number
I am using original parts lists that show different part numbers
