Need some O rings for VM29 Fuel T-piece
Shed20a
#1 PostAuthor: Shed20a » Fri Sep 27, 2019 7:02 pm
Good evening all,
Every spring when I wake my Z1B from its hibernation, I spend the first few hours waiting for the T-Piece O rings to swell up and stop petrol pissing all over the engine. I thought this winter I'd treat the carbs to some new O rings.
Trouble is Allens Performance haven't got any in stock and from Z1 Enterprises the postage cost is 5 times more than the cost of the O rings. I've been looking on the interweb for other places in the UK to buy some from, but nothings come up so far.
If anybody knows where I can get some from it would be appreciated.
Cheers, Stuart
Work to ride, ride to work...
DavidZ1R
Re: Need some O rings for VM29 Fuel T-piece
#2 PostAuthor: DavidZ1R » Fri Sep 27, 2019 7:53 pm
Have you tried Vapourworx
#3 PostAuthor: zed1015 » Fri Sep 27, 2019 7:54 pm
If you know the measurements any good bearing shop should be able to supply them.
Simply bearings or Bearing boys etc have online shops you can search and order from.
Shed20a
#4 PostAuthor: Shed20a » Sat Sep 28, 2019 7:47 am
Thanks for the replies guys.
I could take an O ring out to measure it, but knowing my luck after 40 years of service they'll fall to pieces as soon as I remove them, then I'll have no O ring to measure and no bike to ride..
I'll drop Vapourworx an email later.
Thanks again,
Stuart
Wrigers
#5 PostAuthor: Wrigers » Sat Sep 28, 2019 9:35 am
http://nrp-carbs.co.uk/
Try these, pretty comprehensive range of carb parts..
Shed20a
#6 PostAuthor: Shed20a » Sun Sep 29, 2019 7:38 am
Thanks for the link Wrigers,
I had a look at their shop. They sell T Pieces complete with O rings but they don't sell O rings individually, and they don't explicitly mention VM29 carbs just the standard Z1/Z1A/Z1B/Z900 carbs, and I don't know if they're the same or not.
Stuart
#7 PostAuthor: ZedHead » Sun Sep 29, 2019 9:38 am
If you are not in a hurry, I can get them.
Shed20a
#8 PostAuthor: Shed20a » Sun Sep 29, 2019 11:36 am
Hi ZedHead,
Thanks for the offer, but I've been trawling through ebay and just come across the advert below - four VM29 Smoothbore O-Ring Gasket Kits for for 30 quid.
I didn't fancy forking out 16 dollars postage for 3 dollars worth of O rings from the USA, but from here for 30 quid you get all the O rings plus the float bowl gaskets, including postage.
I'm going to give them a try. Thanks to all for your input.
Cheers, Stuart
https://www.ebay.co.uk/itm/Mikuni-VM-29 ... SwFSRbkF~-
#9 PostAuthor: ZedHead » Sun Sep 29, 2019 3:58 pm
Shed20a wrote:Hi ZedHead,
Cheers, Stuart
:up
