Recomended wheel paint for cast wheels
ogri211
#1 PostAuthor: ogri211 » Sun Oct 20, 2019 3:42 pm
I'm wanting to repaint my wheels on my Z1300 which are black, what paint is recommended for doing them?
Kawasaki Z1300
Kawasaki Z900A4
Buell S1 Lightning
Suzuki GT750A
Harley Sportster
Triumph Sprint
Re: Recomended wheel paint for cast wheels
#2 PostAuthor: Philippe » Sun Oct 20, 2019 4:21 pm
Hi ogri211
you need a dull/satin black 2 component paint (paint and hardener).
remove the old paint as much as possible
polish the aluminium parts which have to stay unpainted, degrease the whole wheel with aceton
tape the shiny aluminium parts off
spray the wheel and let the paint cure overnight
peel off the tape
protect the non sprayed parts with a clear coat for alloys
job done (after a few days of work)
#3 PostAuthor: z1bman » Mon Oct 21, 2019 12:03 pm
best match to the original great paint
https://www.ebay.co.uk/itm/1-X-400ml-GE ... Swmt5c2qP~
Sgt.Pinback
#4 PostAuthor: Sgt.Pinback » Mon Oct 21, 2019 2:06 pm
z1bman wrote:best match to the original great paint
Can´t read the RAL number. Does it say RAL 9005?
That is first choice for frame and brackets. For wheels thats too glossy, IMHO
Cheers, Uli
#5 PostAuthor: Philippe » Mon Oct 21, 2019 3:49 pm
Hi ogri211
I use the Ral 9005(black) Selemix epoxy paint (10% gloss) with hardener. It gives a rather dull finish depending on the amount of hardener you use . The recommended mixture is 4/1/1 (paint,hardener,cellulose thinner).
If you "google" Selemix you can find the manufacturor.
It's a very durable and resistant paint, it adheres to aluminium.
I hope you can find it!
#6 PostAuthor: z1bman » Mon Oct 21, 2019 7:29 pm
i have used this paint for 30 years it is satin black not gloss as it states on the can
#7 PostAuthor: ADRIAN H » Mon Oct 21, 2019 7:54 pm
Good satin black paint :)
nicomkii
#8 PostAuthor: nicomkii » Thu Oct 31, 2019 1:16 pm
Did my MkII wheels with the Worths paint as stated here and these are the wheels after 21,000km
Nico
KWACKERZ1
#9 PostAuthor: KWACKERZ1 » Sat Nov 02, 2019 2:45 pm
Frost restorations extreme chassis black is excellent for swing arms wheels etc.
