z900 overcharging
davidcouzens
- Regular Poster
z900 overcharging
looking for some help with my z900 a4 that is overcharging. i have between 16-17 dc volts at about 3000 rpm. my knowledge is limited as are my test equipment, i only have a cheap digital multimeter. I have tested the resistance between the regulator brown and black wires and this is ok, no other readings between any other wires on the regulator.
my bike has the regulator under the battery box and std rectifier mounted on the electrical plate. I also have another item which looks like a regulator and is shown for sale as a rectifier on ebay but i'm confused with this item.
here is a photo of said item, could someone tell me what this is?
im using a motoball battery from a different bike.
Re: z900 overcharging
OEM Regulator is a well known weak link in the Z1 electrics. Bin it and get a combined modern Reg/Rec unit
davidcouzens
- Regular Poster
yes thanks for that, surely the most sensible option, however does anyone have any idea what the pic is off please?
many thanks
Dave
many thanks
Dave
its a regulator for the hazard lights nothing to do with the charging system
davidcouzens
- Regular Poster
many thanks for identifying this as was doing my ed in.
will press on with reg/rectifier replacement.
i see the Electrex items are mentioned favorably on here, I live near to Vehicle Wiring Products and notice they do one too, anyone tried theirs?
Regards
Dave
Regards
Dave
- 8 Valve Mark
David historically 250/400 super dream combined reg/recs were a good mod (Hitachi) but recently I've read that modern cbr600 are the current equivalent. that's all i know really ; probably worth looking into? or use a combined z1000 unit. m
I don't know the answer to your regulator / rectifier issues but can advise you to change your side panel rubbers... soon!
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
Previous Zeds:
1975 Z1B
1982 Z650F3
Gonzo wrote:I don't know the answer to your regulator / rectifier issues but can advise you to change your side panel rubbers... soon!
Good point. I've heard of several panels flying down the road due to poor fixing
davidcouzens
- Regular Poster
many thanks for the link, all other comments noted
any modern 5 wire reg/rec will work.
Julian_Boolean
Regulator rectifier is fecked if it's overcharging, replace ASAP or you'll have a cooked battery.
