Carbs Fcuking things
mikey
#1 PostAuthor: mikey » Wed Mar 26, 2008 8:45 pm
Guys im realy desperate to take my Z1000A2 to th ace on the 20th.
But i have nothing but greif with the carbs.
Starting from cold ok but it starts by running on 2 or 3 pots then as it gets warm idling on choke the last pot cuts or sometimes it dont and i gota clean
the plug, all the while its backfiring and popping till the last pot cuts in when
it does the backfiring stops and you can turn the choke off and start to rev it.
Its done 250 miles since i rebored it end of last summer and its started to smoke a bit felt end of exhaust and its dry not oily wet, its running standard airbox & filter standard jets, done the shims checked the timing its running dyna s ignition and coils, balanced the carbs best i could but im no expert at it. When i ride it pulls the gears ok but it just feels rough and not right if you know what i mean.
I would appreciate any help cuz i wanna take it, got me ZZR 1100 bit it aint no Z!! :(
Skunkwurcx
#2 PostAuthor: Skunkwurcx » Wed Mar 26, 2008 9:22 pm
I would say get the carbs synced properly and see what happens after that.
mikey
#3 PostAuthor: mikey » Wed Mar 26, 2008 9:39 pm
Hi skunk seems way to go just geting a price to do it now
paulstrees
#4 PostAuthor: paulstrees » Wed Mar 26, 2008 10:36 pm
Had a similar problem, check all the carb rubbers are tight and rebalance the carbs making sure they all fall within 20-23 cm adjusting tickover accordingly. If any are registering a high reading they will not draw enough fuel.
Good luck
RALPHARAMA
#5 PostAuthor: RALPHARAMA » Wed Mar 26, 2008 10:44 pm
What plugs are you using Mikey? If you're using NGKs bin the fuckas and get some Nippon Densos from http://www.spark-plugs.co.uk/index.htm. They're about a quid a piece and are the donkey's private parts. :D
Ralph Ferrand
mikey
#6 PostAuthor: mikey » Thu Mar 27, 2008 5:13 am
Cheers paul and ralph i got a price to do them
last night said they re set them to factory settings
and go from there i gota get some one to do it cuz last
time i tried lost it big time threw me vaccum gauges out
the garage door and they a bit broke :oops:
#7 PostAuthor: Rich » Thu Mar 27, 2008 6:43 pm
First check fuel heights and air leaks from the rubbers, then sync the carbs.
mikey
#8 PostAuthor: mikey » Thu Mar 27, 2008 9:10 pm
Got it booked in saturday week get the carbs done and general tune up
guys im using used before pretty good thanks for your help anyway lads.
RALPHARAMA
#9 PostAuthor: RALPHARAMA » Thu Mar 27, 2008 10:26 pm
You're more patient than me Mikey!
I have a mate in Shire who might be persuaded to do it sooner for a handful o beer tokens. Can vouch for his competance!
Ralph Ferrand
Users browsing this forum: Bing [Bot] and 63 guests
