Clock bracket foams
Advertise your BIKES and PARTS here
z2.john
Clock bracket foams
#1 PostAuthor: z2.john » Mon Nov 11, 2019 11:17 am
A few years ago I looked into getting accurate copies manufactured for the clock foams. I got a sample set made in sticky back EPDM foam. They were potentially an excellent alternative with perfect fit and sponginess but at the time they could only do 5mm thick which was too thick. I can now get these cut in 3mm EPDM but there is a MOQ of 25 sets if I proceed. I’d need to sell at £10 a set to cover the costs if anyone is interested.
Below are some images but bear in mind this was the 5mm thick sample. The first image is a 3D representation in 3mm.
Gonzo
Re: Clock bracket foams
#2 PostAuthor: Gonzo » Mon Nov 11, 2019 11:40 am
I spent quite some time making templates and painstakingly cutting out my foam replacements back in April and could have really done with these then!
1978 Z1000A2
Previous Zeds:
1975 Z1B
1982 Z650F3
lex84
#3 PostAuthor: lex84 » Mon Nov 11, 2019 12:45 pm
John,
I am interested. I want one set!
#4 PostAuthor: Ultim8pc » Mon Nov 11, 2019 12:54 pm
I'd take at least 3 sets.
marmck
#5 PostAuthor: marmck » Mon Nov 11, 2019 1:05 pm
John , If there for a Z1 ,I will have a set please
z2.john
#6 PostAuthor: z2.john » Mon Nov 11, 2019 1:26 pm
marmck wrote:John , If there for a Z1 ,I will have a set please
Yes, they will do for Z1 to Z1B. I should point out that if you have the Z1A/B with the stop light in the tacho, you will need to make a simple scissor cut as below on one of the foams to allow the bulb holder to sit properly.
OK.....I'll get a batch made up and let anyone interested know when they arrive.
John
sprint
#7 PostAuthor: sprint » Mon Nov 11, 2019 4:14 pm
Will they also fit the Z900 A4's?
z2.john
#8 PostAuthor: z2.john » Mon Nov 11, 2019 5:16 pm
sprint wrote:Will they also fit the Z900 A4's?
Sorry, I don't know. I've never had a Z900
walshyco
#9 PostAuthor: walshyco » Mon Nov 11, 2019 5:36 pm
I will buy a set please.
jonhunt
#10 PostAuthor: jonhunt » Tue Nov 12, 2019 7:42 am
I’ll take a set
Keefleaf
#11 PostAuthor: Keefleaf » Tue Nov 12, 2019 9:52 am
2 sets please
sprint
#12 PostAuthor: sprint » Tue Nov 12, 2019 10:03 am
Can anybody advise if the seating platform for the instruments is the same or similar for the Z900 A4's?
Adrian90s
#13 PostAuthor: Adrian90s » Tue Nov 12, 2019 11:52 am
I will have a set too please.
Adrian..adriannurney@hotmail.co.uk or 07952925336
steve-g
#14 PostAuthor: steve-g » Tue Nov 12, 2019 3:36 pm
I will have a set please.
sprint
#15 PostAuthor: sprint » Tue Nov 12, 2019 4:21 pm
Looking at the photos of both the Z1 and Z900 A4 side by side they look to have identical/similar instrument mounting platforms? Though they do not seem to use the round pads?
So on that basis can you please reserve a set for me.
Andy
Return to “For Sale”
