Hi, I have a set of CV carbs that came with a KZ1100 Spectre 1981 that I recently purchased. They are not the origional carbs for this bike. The markings on the are Keihin 173.9 UJ06. They have a choke lever (as oppost to a pull bar) and a butterfly choke system. The seal for the float bowl is a rubber seal not a gasket. They match up to the inlet rubbers on the bike and the air box rubbers are the correct size. I would like to know what bike these came on as i need to replace some bits on them...
Cheers.
Carb ID...
Re: Carb ID...
Thanks z1bman...
