Anyone have a single cam cap floating about Ideally number 1. Any will do. Appreciate these were line bored etc.etc. Had good success in altering in the past. Need to adapt one to fit an old head I have to make it serviceable.
P
Wanted- Cam Cap
Re: Wanted- Cam Cap
Hi, you can only use numbers 1 or 3 caps in the 1 position as these are slightly different to 2 and 4 as they control cam end float .
If it was a 2 or 4 you had to replace you could use any.
Re: Wanted- Cam Cap
Will look in the parts bin Friday to see what i have, will let you know one way or another.
Re: Wanted- Cam Cap
You have mail P.
Re: Wanted- Cam Cap
Kev,
Have responded. Thanks
P
P
Re: Wanted- Cam Cap
Did you get this sorted?
