wanted: Z1000-H fuel injection body parts and seat
Gus
Re: wanted: Z1000-H fuel injection body parts and seat
#16 PostAuthor: Gus » Mon Jan 20, 2020 5:19 pm
Sgt.Pinback wrote:MK2 and H fuel tanks look similar but have different part numbers (apart from the paint code, of course).
MK2 is 51001-1011
H is 51001- 1046
Any idea what´s the difference?
Fuel return from FI system
"Set the GRINDER on it"
ollie
#17 PostAuthor: ollie » Mon Jan 20, 2020 6:17 pm
as gus says there is a fitting on the underside of the tank for the fuel return valve
Sgt.Pinback
#18 PostAuthor: Sgt.Pinback » Mon Jan 20, 2020 6:20 pm
Thanks!
Cheers, Uli
rpeters
Bristol's "H" Hoarder
#19 PostAuthor: rpeters » Tue Jan 21, 2020 9:53 am
MK2 is 51001-1011
H is 51001- 1046
The H tank has a mounting boss for the fuel return NRV on the right hand side (opposite side from fuel tap).
paid up member
rpeters
#20 PostAuthor: rpeters » Tue Jan 21, 2020 9:55 am
:oops: sorry didn't see page 2 answer!
paid up member
Gus
#21 PostAuthor: Gus » Tue Jan 21, 2020 10:25 am
rynner wrote:Hi,o would be more than happy to take any non original or replica parts off you if you don't need them,
any pointers as to where side panel badges can be had,
Atb,ryn
https://www.ebay.co.uk/itm/KAWASAKI-Z10 ... SwHnFVrNnX
#22 PostAuthor: chrisu » Tue Jan 21, 2020 3:14 pm
Atb,ryn
I've got a pair of original FI badges somewhere.............
ollie
#23 PostAuthor: ollie » Tue Jan 21, 2020 7:03 pm
Forgot to say, also the fuel tap is different on mk2 and H tanks .H tanks have the screw type fitting tap like the z1rs and earlier tanks .
Sgt.Pinback
#24 PostAuthor: Sgt.Pinback » Wed Jan 22, 2020 3:17 pm
Thanks. Here are the pics to the answers.
Will have to find the correct fuel tap
Cheers, Uli
