Got 2 sets of carbs, what are they
Z1B
#1 PostAuthor: Z1B » Sun Jan 26, 2020 10:02 pm
Enclosed three photos of first set
Always Learning. :wink
Z1B
Re: Got 2 sets of carbs, what are they
#2 PostAuthor: Z1B » Sun Jan 26, 2020 10:05 pm
Next set
#3 PostAuthor: zed1015 » Sun Jan 26, 2020 10:50 pm
Both VM28SS.
One set probably Z1R with the tick over screw being underneath.
The other has the vac tap take off on #3 carb so maybe MK2 or ST.
Air correctors fitted to the second set.
Pic's of first set doesn't show the fronts.
Z1B
#4 PostAuthor: Z1B » Mon Jan 27, 2020 9:45 am
Other carb side
#5 PostAuthor: zed1015 » Mon Jan 27, 2020 10:32 am
Those are 28mm pumpers from a US model.
Probably MK2 or ST again with #3 vac port but don't know for sure with the US models if there was a vac tap on the Z1R's too .
Best of the bunch in good condition.
Should have just the square diaphragm on carb #2 functioning and the triangle one a blank casting.
Z1B
#6 PostAuthor: Z1B » Sun Feb 02, 2020 10:33 pm
Thanks for the reply, here is a side shot
Users browsing this forum: Bing [Bot] and 21 guests
