Z900 tank ,,
Stogmuller
Z900 tank ,,
#1 PostAuthor: Stogmuller » Sat Feb 08, 2020 10:53 pm
Does anyone know if a kwaka 750 twin petrol tank is same as Z900 ,,circa 1975/6,,,? :D
Re: Z900 tank ,,
#2 PostAuthor: Philippe » Sun Feb 09, 2020 5:58 am
Hi Stogmuller
the Z750 twin tank looks the same but it's not. The place to screw the fuel tap on is more up front compared to a Z900 fuel tank.
The fuel tap might hit the carbs.
Stogmuller
Re: Z900 tank ,,
#3 PostAuthor: Stogmuller » Sun Feb 09, 2020 2:19 pm
Stogmuller
Re: Z900 tank ,,
#4 PostAuthor: Stogmuller » Wed Feb 12, 2020 12:57 pm
Hi my z900 tank is very rusty and has pinhole leak ,, can it be repaired or is it best to just look for a better tank,?
Sgt.Pinback
Re: Z900 tank ,,
#5 PostAuthor: Sgt.Pinback » Wed Feb 12, 2020 1:11 pm
Stogmuller wrote:Hi my z900 tank is very rusty and has pinhole leak ,, can it be repaired or is it best to just look for a better tank,?
2 x yes
Cheers, Uli
Andrew_s
Re: Z900 tank ,,
#6 PostAuthor: Andrew_s » Wed Feb 12, 2020 2:42 pm
The pinhole can be repaired, but depends on the overall condition of the tank, where and how much rust there is as to the whether this is an economical option. Horses for courses I guess, but don't be persuaded by someone that may have a tank to sell you or one you've seen on eBay, as most second hand tanks are second hand for a reason unless you know the tank's origin.
By way of example, my survivor 1970 CB750's tank was rusty inside from stale fuel standing in it for over 4 years. I had it chemically stripped and this exposed a pinhole which had been poorly epoxy resin repaired. The pinhole was repaired correctly (tinned), the tank lined, dents filled and then resprayed. It wasn't the cheapest way to go about it, but the tank is original to the bike.
Current Bikes:
2023 R1250 GSA
Stogmuller
Re: Z900 tank ,,
#7 PostAuthor: Stogmuller » Thu Feb 13, 2020 5:46 pm
Hmmm , cheers lads for advice, my tank is really rough with thick rust inside,,! I suspect after chemical stripping it would resemble a sieve,,,realistically I think decent second hand is way to go ,,
Stogmuller
Re: Z900 tank ,,
#8 PostAuthor: Stogmuller » Thu Feb 13, 2020 5:47 pm
Bike looks ace by the way :D
Users browsing this forum: Kev1R and 80 guests
