J Engine Alternator Casing Wiring Plug
Julian_Boolean
#1 PostAuthor: Julian_Boolean » Mon Feb 24, 2020 2:30 pm
Has anybody got a spare plug for the Alternator casing on a J engine, I've removed my alternator and need to plug the hole in the casing, we have tried filling the hole with instant gasket but it leaks with a steady drip when the bike is on it's side stand. The plug isn't available as a separate part from the alternator coils, so I was wondering if anyone had an old one from an alternator they're not using that I could purchase.
Re: J Engine Alternator Casing Wiring Plug
#2 PostAuthor: zed1015 » Mon Feb 24, 2020 2:49 pm
Available from ZPOWER .
Nearly £14 before post though.
http://www.z-power.co.uk/alternator-cover-grommet
Julian_Boolean
#3 PostAuthor: Julian_Boolean » Mon Feb 24, 2020 2:57 pm
zed1015 wrote:Available from ZPOWER .
Do you know that it's the same as a J one as it says it's for the earlier engines.
#4 PostAuthor: zed1015 » Mon Feb 24, 2020 3:38 pm
Pretty sure it is.
Same part comes up if you search in Z1000J/Z1100.
Julian_Boolean
#5 PostAuthor: Julian_Boolean » Mon Feb 24, 2020 3:48 pm
Cheers I'll order one now
