cast alloy repair?
8 Valve Mark
cast alloy repair?
#1 PostAuthor: 8 Valve Mark » Sat Mar 14, 2020 11:44 pm
does anyone have any experience with regards to fixing a broken carbs' float post? it's a clean break above the pivot pin at about a 45 degree angle. possibly tig-able or with one of the wonder rods that you see on the interweb? any help or recommendations welcomed, it's a small fiddly job more suited to a jeweller than someone who fabricates pylons! :lol: m
Re: cast alloy repair?
#2 PostAuthor: Al » Sun Mar 15, 2020 9:24 am
I have a vague memory of someone doing this on here and i believe they drilled first and put a peg or thin dowel in it and then got it welded.
If you cant find someone to do it send me a pic of whats involved.
It may be easier to build it up rather than stitch the original bit back on.
#3 PostAuthor: Ultim8pc » Sun Mar 15, 2020 11:06 am
The super fastidious Brian at Centurion Motorcycle Projects has repaired quite a few:
https://www.facebook.com/centurionmotorcycleprojects
8 Valve Mark
#4 PostAuthor: 8 Valve Mark » Thu Apr 02, 2020 9:40 am
thanks for the replies (Al and nigel) I will sort out some photos and send them to you Al. keep safe out there.. m
#5 PostAuthor: Al » Thu Apr 02, 2020 10:43 am
Send me a picture or post it on here Mark.
Ive spent a fair bit of time recently, building up un-obtainable cast and alloy moldings / components etc. with TIG but its not what i do. The lad i work with is eleventy million times better at it than me but as you guessed, its not that easy to find the correct method.. meaning rods etc.
