Needle Bearing Puzzle
LeeJackson
Chaps
I have a question that hopefully someone can help with. Rebuilding a Z750E Engine for my 650 project and all the gearbox bearings etc arrived so started piecing back together. Anyway each transmission shaft has a needle roller bearing on it and on the parts diagrams it shows to be 92046-1030, BEARING,VS20/14A.
So two arrives packaged as this part number, the ID is correct but the OD is too small. Which is rather strange. Checking the parts application this bearing seems to be common to all the smaller motors 550 thru 750. The bearings in my engine have a 20mm is and 27mm OD, the ones that I got are a smaller OD. So what I am trying to figure out is if I have the wrong part number or the parts supplier are labeled wrongly..
Does anyone know what size 92046-1030, BEARING,VS20/14A should be? I am guessing the 20 is the OD which is correct, but OD no indication.
Lee
Lee
Re: Needle Bearing Puzzle
Koyo VS20/14A specification below, which shows an OD of 26mm: -
https://bearingsize.info/catalogue-onli ... 09820.html
CMSNL show the bearing as fitting an 80-83 Z750E, but I assume yours is a later model?
LeeJackson
Coose
Good to hear from you! Sorry I meant to say ID 20mm, I measured 27mm od on the bearing but they are a bit tricky to get a proper measurement on so that sounds like the guy. The ones supplied in the kawasaki packets as closer to 24mm of and narrower so sounds like the issue is they supplied the wrong bearings in the right wrapper.
Cheers Man!
Cheers Man!
Not a problem, Lee! I would return the ones you have and just order the correct bearings from Simply Bearings or Bearing King.
My little Z400J uses the same size.
I'm almost certain these bearings also had a bushing that fitted over them- maybe that bushing would account for your diameter difference?
I could be talking rubbish (I'm really good at that!), or you probably already know this stuff, but mentioning it just in case.
EDIT. 92028A and 92028B in this diagram.
2006 ZRX1200R
1982 Z400J project
ex owner of Z1100R
GXI 2752 are you out there?
1982 Z400J project
ex owner of Z1100R
LeeJackson
Correct there is a Bush on them but it’s 2mm bigger than the Kwak bearings I got. Fairly suede they bagged the wrong bearings but I have ordered off the simplybearings site as suggested so will find out soon. Cheers Guys!
LeeJackson
Ok now I’m really confused. I order bearings as identified but still not correct when they arrived which makes me wonder if I’ve identified this engine wrongly!?!. Does anyone have a way to confirm the engine number by year etc? Engine Number is KZ750EE083455
Thanks guys!
Lee
Thanks guys!
Lee
Maybe the engine colour may help if it hasn't been altered.
By my kawasaki spec. manual I think it could be from one of these as the engine numbers start from :
750R1 KZ750EE066907 Black engine
750L2 KZ750EE066893 Black engine with aluminium highlights
750H3 KZ750EE062601 All aluminium
750E3 KZ750EE062623 Black engine with aluminium highlights
Bit confusing but it may help.
Gus
Gus
"Set the GRINDER on it"
cradley have them both in stock & they will check the dimensions
https://www.cmsnl.com/kawasaki-kz750e1- ... npd5er7TeZ
https://www.cmsnl.com/kawasaki-kz750e1- ... npeU-r7TeZ
LeeJackson
Seems that the bearings in question are all listed as the same for nearly every year. I’ll have a surf through various diagrams I guess and see what I can find. Everything else is identical just these two needle bearings! Grrr
why are you replacing these bearings they are normally bulletproof ? the two items you are looking for fits all of the four cylinder engines z400 / z500 /z550/ all z650s all 750s
LeeJackson
BEARING-NEEDLE,20V27 Not Available
I think this is the one.. GPZ Engine has a larger bearing...
LeeJackson
z1bman wrote:why are you replacing these bearings they are normally bulletproof ?
Ok
That’s a good question and I did consider to reuse them but figured that while I’m replacing everything else it would be sensible to change them too. Maybe no point?
BEARING-NEEDLE,20V27 part no 92046-1045 is from the uni trac models cradley have it in stock
