Oil filter drain plug
The oil filter drain plug on my Z1A is damaged. I’m going to replace it. From memory I don’t think there’s a washer or o ring under it. Should there be?
Re: Oil filter drain plug
Hi Jon, I'm not sure, just saying hello
but I thought it should have an alloy washer
"Set the GRINDER on it"
Not the oem solution, but I use dowty sealed washers on all sump plugs, car or bike.
A better solution IMO if you can get them and reusable without annealing (I generally aquire them from work).
Olly
Olly
Lemmy
Lemmy
Gus - item #20
Mr Bump - can you anneal a Dowty washer - thought they has rubber seal built in?
Pigford wrote:Gus - item #20
Hi Mark.
Are you well?
I just went by what John asked for. The "oil filter drain bolt" not the "sump drain bolt".
Gus
Gus wrote:Pigford wrote:Gus - item #20
Hi Mark.
Are you well?
I just went by what John asked for. The "oil filter drain bolt" not the "sump drain bolt".![]()
Gus
Hi matey - ah yes, I (as usual) didn't read it properly!
....what I meant was you might have to anneal or replace a copper washer or replace an ally washer, but because the dowty washers are rubber sealed they are reusable without any messing about.
Olly
Lemmy
Lemmy
Mr Bump wrote:Pigford wrote:Gus - item #20
Olly
