Brackets in front of battery case Z1000A1
TiBolts
#1 PostAuthor: TiBolts » Thu Apr 02, 2020 1:49 pm
Hi all
See graphic - I'm missing parts 15 and 20. Anyone got a photo of how they fit together on the bike? Or can someone take a photo if they have a standard Z1000A1? The parts manual doesn't really help and I got the bike already dismantled, with a few bits missing. Haven't been able to find a really good pic of this online (I've seen some Z1 ones but they're a bit different).
Gus
Re: Brackets in front of battery case Z1000A1
#2 PostAuthor: Gus » Thu Apr 02, 2020 2:54 pm
I'm sure I've got a 15 somewhere you can have.
Gus
"Set the GRINDER on it"
TiBolts
#3 PostAuthor: TiBolts » Thu Apr 02, 2020 4:01 pm
Cool! Thanks Gus. There's no rush, obviously.... hope you're keeping out of harm's way :)
Gus
#4 PostAuthor: Gus » Thu Apr 02, 2020 6:05 pm
Trying to but they keep making me come to work.
I'll root out the part.
DavidZ1R
#5 PostAuthor: DavidZ1R » Thu Apr 02, 2020 6:16 pm
No. 20 fits at the bottom and to the rear of the battery box, it bolts to the frame
damien.wrl
#6 PostAuthor: damien.wrl » Fri Apr 03, 2020 8:41 am
Recently had the battery box powder coated and don’t recall 15 being part of it.. the tool holder is pictured in this schematic and is not part of it either, could the part be elsewhere?
Think 20 bolted to the frame as a bracket to mount the box to...
popsA1
#7 PostAuthor: popsA1 » Fri Apr 03, 2020 9:06 am
Using bolt 11, 15 sits on top of the rubber grommets that secure 17 to 20. 20 blots to the frame.
A2 1979-80. A1 1980-now
Gus
#8 PostAuthor: Gus » Fri Apr 03, 2020 11:09 am
Gus wrote:Trying to but they keep making me come to work.
Got one for you
PM sent.
Gus
damien.wrl
#9 PostAuthor: damien.wrl » Fri Apr 03, 2020 11:19 am
popsA1 wrote:Using bolt 11, 15 sits on top of the rubber grommets that secure 17 to 20. 20 blots to the frame.
So 15 is a clamp ? I have 18 as a clamp
Gus
#10 PostAuthor: Gus » Fri Apr 03, 2020 11:49 am
Doesn't 15 support the air box?
Gus
damien.wrl
#11 PostAuthor: damien.wrl » Fri Apr 03, 2020 2:49 pm
I can’t see 15 at all 20 I think is a mounting bracket to which you bolt the front of the battery tray
You can just see the 20 securing bolt in the second photo between the air intake and the negative battery lead
TiBolts
#12 PostAuthor: TiBolts » Fri Apr 03, 2020 3:02 pm
Blimey it's confusing ain't it? I found this photo which I'm pretty sure shows 15 and 20 together just behind the gearbox. Not sure about 18 at all, except I haven't got it!
Gus has got a 15 I can have - for which many thanks :D
Thanks to everyone else for suggestions. Any more photos/offers of bits would be welcome!
TiBolts
#13 PostAuthor: TiBolts » Fri Apr 03, 2020 3:06 pm
No idea why that photo is in black and white, it was colour when I uploaded it.
The other thing I'm really interested in in this area is how the end of 20 fits to the rear rh engine mounting bracket - I have two of these rear engine mounting brackets but they seem to foul the mount for the rear master cylinder (which as I'm sure you'll all know is welded to the frame) so I suspect they might be from a Z900.
Any info?
damien.wrl
#14 PostAuthor: damien.wrl » Fri Apr 03, 2020 5:27 pm
Just checked mine, I don’t have a 15, but there is room for it under the air box, not sure what it does though.. 20 and 15 seem sorted , 18 can be seen in my first picture securing the battery down... Not sure what you mean about securing 20 down, you can see the top of one of the two bolts securing it down in my second pic.. two bright battery tray bolt downs and between the air box inlet and battery earth cable on of the fixing bolts
Another pic of 20 I found of bolted down
TiBolts
#15 PostAuthor: TiBolts » Fri Apr 03, 2020 8:43 pm
Ah so 18 holds the battery down. OK cool thanks. For 20, it appears to bolt to the tangs on the rear engine mount bracket. Just not sure that the engine mounting brackets that I have are the right ones...
