Hi All,
Looking for the grommet that's on the points plate cable that goes to the coils,there's a slot in the casing where it sits this is for a Z1A but I assume there the same across the Z range.
Thank's,
Niall.
Points Plate Grommet
Niall Mehigan
Re: Points Plate Grommet
Niall I might have one will look tomorrow
Have you tried Paul Doran
Zeds-R-Us
The grommet in question appears to have an odd shape in that it has a flat side and is 'D' shaped.
Just a suggestion -
I suppose until one turns up, you could use a 'normal' round (maybe slightly undersize) one with a smear of silicon which should seal against the elements ok.
At least it would allow use of the bike without fear of water ingress knocking the ignition out.
Just a suggestion -
010
Kev,as you said it's D shaped hopefully one will turn up as the Z1A is a restoration project but nearly there now just the carbs and wiring harness to fit and we'll see how it goes,thank you for your suggestion.
Niall.
Niall.
Niall Mehigan
Ive previously cut one out of rubber to shape , seem to remember the hole was a pain in the arse .
got a few points set up now i've removed for electronic ignition so will have a look for one
Thank you 73z1 it's an option if a grommet dose'nt turn up.
Niall.
Niall.
Niall Mehigan
All sorted now thanks to Bill P a gent,and Thank you to ALL who make suggestions/options.
Have a good Easter in whatever shape or form.
Niall.
Niall.
Niall Mehigan
