GPz1100 B2
- new poster
GPz1100 B2
Hi everyone, I hope you are all keeping safe.
Would anyone be so kind as to recommend somewhere for purchasing GPz1100 engine parts, predominantly pistons and rings etc.
After having my bikes parked up waiting form”the right time” to do the long awaited renovation I have actually got round to starting one and would like to keep the momentum going.
Thanks for your help.
Re: GPz1100 B2
IMD pistons might be a good place to start your search ,i've used there stuff and competitive prices to only
beaten by cruzin image on ebay , nice bike by the way enjoy the renovation
CRUZINIMAGE.NET
CRUZINIMAGE.NET
- new poster
Re: GPz1100 B2
Hi, thanks for that I will give them a try.
Re: GPz1100 B2
Hi Duane
welcome to the club!
Nice GPz 1100 you have there.
Before ordering pistons, open up the engine to see if you have a B2 engine...mine had a Uni trac engine and those have a different cranckshaft, other pistons, head and valves, so don't hurry with ordering parts.
Good luck!
Greetings from Belgium
Good luck!
- new poster
Re: GPz1100 B2
Hi Phillips, thanks for the advise.
Would you have some tips as to how I could recognise what the engine came from?
Thanks Duane.
Thanks Duane.
Re: GPz1100 B2
Take the timing casing off (rh side) if it's got mechanical advance mechanism it's a J type engine (GPZ1100B1/B2) if it's got no advance mechanism it's a Unitrak (advance is electronic)
Yours looks like a B2 engine though.
- new poster
- new poster
Re: GPz1100 B2
Hi Gus, so is this a J engine then ??
Re: GPz1100 B2
Your engine number should be in between these numbers I believe for a B2 engine.
KZT10BE010401 - 016449
Looking at the front of the barrels lower left hand side it should read 1089cc
Gus
Gus
"Set the GRINDER on it"
- new poster
Re: GPz1100 B2
Hi Gus, it definitely says 1089 on the barrel but the engine number is outside of the range you have supplied. Both bikes have numbers that start with KZT10B - 017. I have two of these 1100,s and both the engine numbers are outside the range.
One bike was registered September 1982 and this one was registered April 1983 !!! I am pretty sure they are both B2 engines though just trying to confirm this. I have also measured the grudgeon pins as I believe the B2 engine has a 17mm pin which this one has.
It would have been nice if Kawasaki actually put B2 on the engines. Suppose it’s a bit late to tell them now
Re: GPz1100 B2
Maybe my number of - 016449 is incorrect.
Somebody maybe along with a better answer.
Gus
Gus
- new poster
Re: GPz1100 B2
Thanks for your help, I’m sure everyone on here will be sick of me by the time I’ve got them both finished.
If I find out any more I’ll let everyone know.
Stay safe.
Stay safe.
Re: GPz1100 B2
GPZ1100 A1 Unitrack engine numbers start - ZXT10A - 00xxxx
- new poster
Re: GPz1100 B2
Hi Adrian, with mine being KZT10B-**** I could safely assume that they are B2 engines ??
Thanks.
Thanks.
