Front brake master cylinder
Adrian90s
#1 PostAuthor: Adrian90s » Mon Apr 20, 2020 7:35 pm
the bar mounted brake master cylinder on my 1973 Z1 is grey, is this correct or is the satin black worn off?
Many thanks
Adrian
Re: Front brake master cylinder
#2 PostAuthor: ADRIAN H » Mon Apr 20, 2020 7:36 pm
Pretty sure it should be satin black.
#3 PostAuthor: Philippe » Tue Apr 21, 2020 5:33 am
Hi
the original satin black can turn into a deep purple shade due to the sunlight. I'm not sure about the grey...
z2.john
#4 PostAuthor: z2.john » Tue Apr 21, 2020 5:59 am
Philippe wrote:Hi
Phillippe is correct, original is satin black, then they fade to shade of purple then eventually grey when the sun exposure has been excessive as seen here..
Adrian90s
#5 PostAuthor: Adrian90s » Tue Apr 21, 2020 10:48 am
Yep, thats the colour of mine, suppose I better paint it.
Adrian
wilsonsjw11
#6 PostAuthor: wilsonsjw11 » Tue Apr 21, 2020 7:37 pm
Don't paint it, get it re-anodised
Mark Hutton did offer the service.He will also rebuild the internals if it's any good and worth saving
Regards
Steve
bedlow1
#7 PostAuthor: bedlow1 » Wed Apr 22, 2020 4:43 pm
wilsonsjw11 wrote:Don't paint it, get it re-anodised
Regards
Steve
steve didnt know he did this i will give him a try as ive got 2 euro ones with the clear plastic sight that need doing. The last one i powder coated it and some brake fluid weeped on to it and bubbled the pain. Hence i use dot5 silicone fluid now.
Graham
1972 Z1 Euro Spec
1975 Z1B UK Bike
Adrian90s
#8 PostAuthor: Adrian90s » Wed Apr 22, 2020 4:52 pm
Hi Graham
Please contact Steve, I would like mine doing too.
I have had the master cylinder and caliper overhauled.
Regards
Adrian
wilsonsjw11
#9 PostAuthor: wilsonsjw11 » Wed Apr 22, 2020 7:22 pm
I'm pretty sure the master cylinder has to be stripped of internal/external parts prior to the anodising process as it involves heat.He will apply the same process to the 3 way brake splitter too.
Regards
Steve
Adrian90s
#10 PostAuthor: Adrian90s » Wed Apr 22, 2020 8:32 pm
Is it doable? Mine has been re- furbed but I will pay for it again providing its not a fortune.
Ady
z2.john
#11 PostAuthor: z2.john » Thu Apr 23, 2020 7:07 am
Word of warning..... I had one re-anodised a few years back but the finish came out too glossy.
Once it has been de-anodised there are 2 options. Polish or leave alone. If you polish the final finish will be glossy or if you leave it the final finish will be too matte. The only way to get a satin finish is to find NOS or re-paint :(
Adrian90s
#12 PostAuthor: Adrian90s » Thu Apr 23, 2020 8:37 am
Thanks for that John,
I've ordered some aluminium primer paint then I will try normal satin spray...could that work?
Ady
wilsonsjw11
#13 PostAuthor: wilsonsjw11 » Fri Apr 24, 2020 4:39 pm
Stipulate satin black and as close to OEM finish.
Regards
Steve
wilsonsjw11
#14 PostAuthor: wilsonsjw11 » Fri Apr 24, 2020 4:42 pm
Does anyone offer a master cylinder sleaving service as I have a perfect 5/8 unit but the bore is pitted.
Regards
Steve.
#15 PostAuthor: kev edwards » Fri Apr 24, 2020 6:37 pm
Past parts in Bury ST Edmunds, they done a triangle A2 cylinder for me, sleeved in stainless cost about £60 posted, i spoke on the phone with them, very tidy job, cylinder sitting in the loft now boxed up as i did not use it in the end.
http://www.pastparts.co.uk/
