Front brake master cylinder
the bar mounted brake master cylinder on my 1973 Z1 is grey, is this correct or is the satin black worn off?
Many thanks
Adrian
Many thanks
Adrian
Re: Front brake master cylinder
Pretty sure it should be satin black.
Hi
the original satin black can turn into a deep purple shade due to the sunlight. I'm not sure about the grey...
Philippe wrote:Hi
Phillippe is correct, original is satin black, then they fade to shade of purple then eventually grey when the sun exposure has been excessive as seen here..
Yep, thats the colour of mine, suppose I better paint it.
Adrian
Adrian
Don't paint it, get it re-anodised
Mark Hutton did offer the service.He will also rebuild the internals if it's any good and worth saving
Regards
Steve
Regards
Steve
wilsonsjw11 wrote:Don't paint it, get it re-anodised
Regards
Steve
steve didnt know he did this i will give him a try as ive got 2 euro ones with the clear plastic sight that need doing. The last one i powder coated it and some brake fluid weeped on to it and bubbled the pain. Hence i use dot5 silicone fluid now.
Graham
1972 Z1 Euro Spec
1975 Z1B UK Bike
1972 Z1 Euro Spec
1975 Z1B UK Bike
Hi Graham
Please contact Steve, I would like mine doing too.
I have had the master cylinder and caliper overhauled.
Regards
Adrian
Regards
Adrian
I'm pretty sure the master cylinder has to be stripped of internal/external parts prior to the anodising process as it involves heat.He will apply the same process to the 3 way brake splitter too.
Regards
Steve
Regards
Steve
Is it doable? Mine has been re- furbed but I will pay for it again providing its not a fortune.
Ady
Ady
Word of warning..... I had one re-anodised a few years back but the finish came out too glossy.
Once it has been de-anodised there are 2 options. Polish or leave alone. If you polish the final finish will be glossy or if you leave it the final finish will be too matte. The only way to get a satin finish is to find NOS or re-paint
Thanks for that John,
I've ordered some aluminium primer paint then I will try normal satin spray...could that work?
Ady
Ady
Stipulate satin black and as close to OEM finish.
Regards
Steve
Regards
Steve
Does anyone offer a master cylinder sleaving service as I have a perfect 5/8 unit but the bore is pitted.
Regards
Steve.
Regards
Steve.
Past parts in Bury ST Edmunds, they done a triangle A2 cylinder for me, sleeved in stainless cost about £60 posted, i spoke on the phone with them, very tidy job, cylinder sitting in the loft now boxed up as i did not use it in the end.
http://www.pastparts.co.uk/
