Kawasaki z1000 a1 starter motor
PaulMceleney
Chunks
#1 PostAuthor: PaulMceleney » Thu Apr 30, 2020 6:46 pm
Starter clutch sticking I think spinning sound from engine and will not disengaged this all started after rotor came loose had this apart.three times now new starter clutch kit fitted could it be because of three bolts on the rotor there is slight movement if you try and move it by hand when it's on the bike but it's not loose what do you think
