Spitting misfire
1340fxd
Spitting misfire
#1 PostAuthor: 1340fxd » Sat May 09, 2020 8:12 pm
Stripped and sonic cleaned the carbs on my KZ1000 and rebuilt with kit from Z-Power. Fitted K&N pod air filters. Got air jets from zed1015 and increased main jets from 107.5 to 112.5.
She fires up and runs really well except for a spitting misfire when cold and coming off choke. This goes as the engine warms up but appears to be lurking occasionally in the background. What should I try to get rid of this please? :lol:
Dear Santa, please can I have...
Re: Spitting misfire
#2 PostAuthor: zed1015 » Sat May 09, 2020 8:52 pm
Assuming all the valve clearances are in spec, spitting back through carbs is a sign of a weak mix or possibly an air leak on one or more of the rubber intake boots.
Try tweaking the mixture screws to richen up the pilot mix.
1340fxd
#3 PostAuthor: 1340fxd » Sun May 10, 2020 5:21 am
Thanks for that and yes, valve clearances just been done. I guess the rubber intake boots don't last forever - do they become porous?
#4 PostAuthor: Pigford » Sun May 10, 2020 6:09 am
They tend to crack/split. For £40, if they're old, well worth changing.
If the spitting goes when motor up to temp, it may just be it's a tad lean as Rob says.
000zeds
#5 PostAuthor: 000zeds » Sun May 10, 2020 7:32 am
Pigford wrote:They tend to crack/split. For £40, if they're old, well worth changing.
http://www.z-power.co.uk/z900-z1-z1a-z1 ... t-z1-z1000
Zeds-R-Us
#6 PostAuthor: Pigford » Sun May 10, 2020 10:01 am
https://www.ebay.co.uk/itm/Kawasaki-Z90 ... Swv0tU7IGU
marmck
#7 PostAuthor: marmck » Sun May 10, 2020 12:19 pm
zed1015 wrote:Assuming all the valve clearances are in spec, spitting back through carbs is a sign of a weak mix or possibly an air leak on one or more of the rubber intake boots.
Similar problem on me Z1 , just to clarify is to richen in or out Ta!
#8 PostAuthor: zed1015 » Sun May 10, 2020 6:01 pm
If it's an air screw on the side then it's out to weaken.
1340fxd
#9 PostAuthor: 1340fxd » Fri May 22, 2020 6:10 am
Problem found and all very silly. I had fitted new fuel pipe obtained from Z-Power which is black and flexible (to replace the clear stuff that had turned hard as nails).
The issue was that the pipe bend became a kink when the temperature rose and the fuel pipe became even more flexible i.e. a few miles into the ride when engine heat had built up a bit. I have now used kart fuel tube which is clear and less prone to kinking - problem solved! :oops:
#10 PostAuthor: zed1015 » Fri May 22, 2020 11:32 am
It's always the little things that cause to most problems.
Users browsing this forum: No registered users and 95 guests
