Bikes a 1976 Z900,,
footrests
Stogmuller
- Regular Poster
footrests
Do the footrest support pins that go into the frame that the footrests themselves sit on screw into the frame,,? Or do they just push in and can be drifted out from rear after removing the nuts,,
Bikes a 1976 Z900,,
Bikes a 1976 Z900,,
Re: footrests
They screw into the frame
Re: footrests
You shouldn't be able to remove the nuts before unscrewing the footrest mounts.
The nut threads onto the mount first, which is then screwed into the frame & the nut is then tightened to lock the mount in position.
download/file.php?mode=view&id=16612
- Attachments
- DSCN3588.JPG (163.08 KiB) Viewed 2761 times
Re: footrests
As already said they screw into the frame with the 'half nut' locking them in place. They will be tight though!
Replacements are available but not cheap - http://www.z-power.co.uk/z900-z1-z1a-z1 ... et-4-front.
- Attachments
- imageJXWEQ1D9.jpg (78.32 KiB) Viewed 2754 times
Wots up DOHC
Re: footrests
sanderz wrote:As already said they screw into the frame with the 'half nut' locking them in place. They will be tight though!
Good job someone is paying attention to what they are reading !! Unlike me
Good picture of the passenger footrest above though, if anybody whats one
Stogmuller
- Regular Poster
Re: footrests
Cheers for help,,
