Good afternoon guys,
Does anyone have a link to buying 12v Glass fuses 1” length 30amp fuses, all on eBay are 30mm
TIA
Glass fuses
Glass fuses
1981 KZ1000 K1 LTD
Re: Glass fuses
He sells them:
10amp
https://www.ebay.co.uk/itm/New-Motorcyc ... 2749.l2649
20amp
10amp
20amp
Re: Glass fuses
This is fairly much a direct replacement for the frail standard fuse box with a little jiggery pokery and enlarging a couple of holes with a drill.
It is not the most robust but better than the original which corrodes round the ring terminals on the underside and in my case; cracked invisibly!!!
https://www.vehiclewiringproducts.co.uk ... e-fuse-box
Fuses here
https://www.vehiclewiringproducts.co.uk ... blade-fuse
Fuses here
Re: Glass fuses
I did away with the fuse holder buy using two female Japanese spade connectors and a car bayonet fuse, although not original it isn’t an issue if you need to replace a fuse.
1975 Kawasaki Z1B
1979 Triumph Bonneville T140D
1969 BSA B25 Starfire
Users browsing this forum: chrisu and 67 guests
