Hi All,
I know the best way to set the Float heights is to use the adaptor and tube to look at the fuel level but could someone tell me if there is a basic float height measurement available so that I can get them somewhere near during assembly?
I guess it’s somewhere between 22mm and 25mm from the float to the upstand on the carb body but a correct dimension would be helpful.
Thanks in advance.
Z1000A1 Float Height
Re: Z1000A1 Float Height
Thank you very much!
Users browsing this forum: Maunders and 72 guests
