What are you doing whilst in 'self-isolation'?
Gyesdad
Re: What are you doing whilst in 'self-isolation'?
#121 PostAuthor: Gyesdad » Sun May 31, 2020 9:50 pm
Bill P wrote:Its a Massey Ferguson FE35 1958 i believe its the correct colour my mate said they turned red in 57 :) yep daily transport with
a piece of straw in corner of my mouth mate
Hey up Gary
all good thanks hope you are to
yep i spotted it :) i've a couple of triumphs myself now
All good here thank you. RX is going well :D
Mentioned the Bonnie as I saw that you'd gone right foot gearchange....
#122 PostAuthor: chrisu » Tue Jun 02, 2020 10:32 am
thought I'd chip in on this.
I've finally got round to getting the Z1000H that's been sat at the back of my garage running. All good now but just added up what i've done. Oh dear... mistake
Oil/Filter
Air filter (NOS)
Fuel Filter (NOS)
New fuel lines
New Fuel Pump (ouch)
New Brake lines and banjo bolts
Front M/C rebuild kit
Rear M/C rebuild kit
Front Calipers rebuild kit
Rear caliper rebuild kits
New Chain and sprockets
New paint all round - plus leaking tank repair by TCP.
Lots of stainless bolts
Footrest nuts and washers
Cables
Tacho
Pingel fuel tap (I have the original rebuilt)
Valve shims done
Plugs and plug caps
Mirrors
Rear axle nut
Wheel bearings
Grab Rail (x2)
New clock loom
Seat Stay
Replacement ECU
Rebuilt injectors
New disc bolts - front and rear.
New bleed nipples
New clutch lever bolt.
Still to do - New Tyres.
Photos are here
https://www.facebook.com/groups/641306573375203/
#123 PostAuthor: Bill P » Tue Jun 02, 2020 10:46 am
Sounds like you'll have a cracking bike now though :)
pity we don't all do Facebook for piccies though but thats life
#124 PostAuthor: chrisu » Tue Jun 02, 2020 10:53 am
good point.
h 3.jpg (127.63 KiB) Viewed 9399 times
h 2.jpg (116.04 KiB) Viewed 9399 times
h 1.jpg (126.88 KiB) Viewed 9399 times
#125 PostAuthor: Bill P » Tue Jun 02, 2020 11:01 am
Beautiful Chris :) Thanks for helping a Luddite out
#126 PostAuthor: r3sc » Tue Jun 02, 2020 4:49 pm
I don’t do Facebook either and glad you posted the images!
Really nice bike! :D
#127 PostAuthor: r3sc » Tue Jun 02, 2020 5:01 pm
Just a couple of follow up photos of the carbs that I’ve stripped and rebuilt.
Just got to bench test and check float heights and then hopefully back out on the road!
I refitted all the original brass etc but changed every gasket, seal and the chewed up JIS screws.
I also re zinc plated the choke lever.
It’s the first time I’ve stripped a set of these and I have to say they’re really nicely made and put together! I like them!
Cheers.
#128 PostAuthor: Bill P » Tue Jun 02, 2020 5:57 pm
Lovely job they look crackin :)
jonhunt
#129 PostAuthor: jonhunt » Tue Jun 02, 2020 9:57 pm
Fitted stuff I bought an age ago. Set of std indicators I bought nearly 2 years ago at Stafford. Found that the relay fitted with the mini ones wouldn’t flash the indicators. A rummage around in an old box of bits I have had for 20 years yielded 2 relays one of which worked. Fitted a new seat lock. Had that a long time too. Fitted a fairing to the CBR 400rr, I’ve had for a year, to replace a cracked one.
Stripped some of the interior out of the MR2 before it goes to get new handbrake cables fitted. Petrol tank has to be dropped to do this task so I’ll leave that to the local garage
Still to do. Service the z1 and fit the Marving exhaust I’ve had for 6 months
MikeP
#130 PostAuthor: MikeP » Wed Jun 03, 2020 10:01 am
chrisu wrote:good point.h 3.jpgh 2.jpgh 1.jpg
That's a lovely looking bike.
#131 PostAuthor: Bill P » Fri Jul 24, 2020 9:12 pm
My latest must relieve the lock down blues ( or thats what i tell the wife )
1967 Hornet :)
MikeP
#132 PostAuthor: MikeP » Sat Jul 25, 2020 7:41 am
Nice looking A65 BillP :luv . I still have mine from 35yrs ago. Slightly modified in a cafe racer style of the day, and a front end change so it stops:
zapo
#133 PostAuthor: zapo » Sat Jul 25, 2020 10:21 am
Bill,
Hardly any room left to swing a zed.
I see Zed people.
#134 PostAuthor: Bill P » Sat Jul 25, 2020 12:24 pm
Thanks MikeP thats a nice looking one you have there ,i guess they were a bit cheaper 35yr ago :)
Theres always room for Kwaks Zapo You keeping well
#135 PostAuthor: ADRIAN H » Sat Jul 25, 2020 1:47 pm
On my Z1000A2 Plenty of polishing going on. I have fitted new tyres, and overhauled the brakes. Also got my new paint set back for my Z1000, which needs fitting, (Not for rivet counters or members of VJMC).
Return to “The Bottom Shed”
