3.4 bulbs
Re: 3.4 bulbs
Yes but 4 w will generate more heat,
I had the neutral light green backing melt when using the wrong bulb.
Personally i would use he correct round bulb (expensive from z-power) but the longer more readily available hence cheaper and longer bulbs can run to close to the plastic cover on zed clocks.
Re: 3.4 bulbs
Although you could use the longer bulbs in the speedo and tacho for ilummination without problems.
Re: 3.4 bulbs
Thanks for that kwaker. A melting neutral backing plastic is the reason I want to use the shorter ones. Tho I will use the longer bulbs in speedo/ tach. The short 3.4 bulbs are available from India if required Tommy
Re: 3.4 bulbs
Gus,
If you have a link to suitable led ones that would be great.
Re: 3.4 bulbs
Here's one but I think there are more manufacturers
https://www.autoelectricsupplies.co.uk/ ... tegory/119
Gus
Gus
"Set the GRINDER on it"
