I’ve got a floppy peg
pablo
#1 PostAuthor: pablo » Fri Jun 19, 2020 3:42 pm
Quiet at the back.
One of my rear pegs is refusing to stay up when told. Does anyone know if there’s an easy fix for this? Z-Power sell pattern replacements for £20 the pair, but I’d rather fix than replace if possible.
Ta.
1976 z900 A4 -- Now, with a little help from Wiseco and Steve Debben, it's a 1048 with rs34 flatsides
Re: I’ve got a floppy peg
#2 PostAuthor: warren3200gt » Fri Jun 19, 2020 4:12 pm
You need to put a thicker washer on it or a washer if you dont have any, Pablo. Sounds like the corners of the peg mount have worn and the peg rubber is no longer acting as enough of a spring against the mount.
Also give the end of the rubber a few whacks with a rubber mallet to ensure its not come off the metal peg which would have the same effect as above.
#3 PostAuthor: Pigford » Fri Jun 19, 2020 4:15 pm
Failing that, squeeze the mounting ears together a bit so it holds it tightly in place.
pablo
#4 PostAuthor: pablo » Fri Jun 26, 2020 9:41 am
Thanks guys - just got around to having a look at it.
Couldn’t find another washer of the same size (ID 25, OD 30) So fabricated one out of foam rubber packing material I had lying around. Does the job short term, but the bracket and pin have worn each other out pretty impressively so I think I might have to go for new replacement.
Unless anyone has a good pair knocking about?
Users browsing this forum: Stugill and 76 guests
